<?xml version="1.0" encoding="UTF-8"?><process version="10.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.3.001" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="10.3.001" expanded="true" height="68" name="Retrieve Lake Huron" origin="GENERATED_TUTORIAL" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/Time Series/data sets/Lake Huron"/> </operator> <operator activated="true" class="concurrency:optimize_parameters_grid" compatibility="10.3.001" expanded="true" height="124" name="Optimize Parameters (Grid)" width="90" x="246" y="34"> <list key="parameters"> <parameter key="Set Macro (Real).value" value="[2;10;5;linear]"/> </list> <parameter key="error_handling" value="fail on error"/> <parameter key="log_performance" value="true"/> <parameter key="log_all_criteria" value="false"/> <parameter key="synchronize" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="operator_toolbox:set_macro_real" compatibility="2.17.000" expanded="true" height="82" name="Set Macro (Real)" width="90" x="45" y="187"> <parameter key="macro" value="uno"/> <parameter key="value" value="3.5"/> </operator> <operator activated="true" class="generate_macro" compatibility="10.3.001" expanded="true" height="82" name="Generate Macro" width="90" x="179" y="238"> <list key="function_descriptions"> <parameter key="dos" value="floor(eval(%{uno}))"/> </list> </operator> <operator activated="true" class="time_series:windowing" compatibility="10.3.001" expanded="true" height="103" name="Windowing (Series)" origin="GENERATED_TUTORIAL" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Lake surface level / feet"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="has_indices" value="true"/> <parameter key="indices_attribute" value="Date"/> <parameter key="sort_time_series" value="false"/> <parameter key="expert_settings" value="false"/> <parameter key="unit" value="example based"/> <parameter key="windows_defined" value="from start"/> <parameter key="custom_start_point" value="5"/> <parameter key="custom_end_point" value="100"/> <parameter key="window_size" value="%{dos}"/> <parameter key="custom_start_time" value="2000-01-01 00:00:00"/> <parameter key="custom_end_time" value="2030-01-01 00:00:00"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="window_size_time" value="1.Hours"/> <parameter key="windows_stop_definition" value="from next window start"/> <parameter key="window_start_attribute" value=""/> <parameter key="window_stop_attribute" value=""/> <parameter key="no_overlapping_windows" value="false"/> <parameter key="step_size" value="1"/> <parameter key="step_size_time" value="1.Minutes"/> <parameter key="create_horizon_(labels)" value="true"/> <parameter key="horizon_attribute" value="Lake surface level / feet"/> <parameter key="horizon_size" value="1"/> <parameter key="horizon_offset" value="0"/> <parameter key="horizon_size_time" value="1.Hours"/> <parameter key="horizon_offset_time" value="0.Minutes"/> <parameter key="horizon_start_attribute" value=""/> <parameter key="horizon_stop_attribute" value=""/> <parameter key="empty_window_handling" value="add empty exampleset"/> </operator> <operator activated="true" class="h2o:deep_learning" compatibility="10.3.001" expanded="true" height="103" name="Deep Learning" width="90" x="313" y="34"> <parameter key="activation" value="Rectifier"/> <enumeration key="hidden_layer_sizes"> <parameter key="hidden_layer_sizes" value="50"/> <parameter key="hidden_layer_sizes" value="50"/> </enumeration> <enumeration key="hidden_dropout_ratios"/> <parameter key="reproducible_(uses_1_thread)" value="false"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="epochs" value="10.0"/> <parameter key="compute_variable_importances" value="false"/> <parameter key="train_samples_per_iteration" value="-2"/> <parameter key="adaptive_rate" value="true"/> <parameter key="epsilon" value="1.0E-8"/> <parameter key="rho" value="0.99"/> <parameter key="learning_rate" value="0.005"/> <parameter key="learning_rate_annealing" value="1.0E-6"/> <parameter key="learning_rate_decay" value="1.0"/> <parameter key="momentum_start" value="0.0"/> <parameter key="momentum_ramp" value="1000000.0"/> <parameter key="momentum_stable" value="0.0"/> <parameter key="nesterov_accelerated_gradient" value="true"/> <parameter key="standardize" value="true"/> <parameter key="L1" value="1.0E-5"/> <parameter key="L2" value="0.0"/> <parameter key="max_w2" value="10.0"/> <parameter key="loss_function" value="Automatic"/> <parameter key="distribution_function" value="AUTO"/> <parameter key="early_stopping" value="false"/> <parameter key="stopping_rounds" value="1"/> <parameter key="stopping_metric" value="AUTO"/> <parameter key="stopping_tolerance" value="0.001"/> <parameter key="missing_values_handling" value="MeanImputation"/> <parameter key="max_runtime_seconds" value="0"/> <list key="expert_parameters"/> <list key="expert_parameters_"/> </operator> <operator activated="true" class="apply_model" compatibility="10.3.001" expanded="true" height="82" name="Apply Model" width="90" x="447" y="34"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_regression" compatibility="10.3.001" expanded="true" height="82" name="Performance (2)" width="90" x="581" y="34"> <parameter key="main_criterion" value="first"/> <parameter key="root_mean_squared_error" value="true"/> <parameter key="absolute_error" value="false"/> <parameter key="relative_error" value="false"/> <parameter key="relative_error_lenient" value="false"/> <parameter key="relative_error_strict" value="false"/> <parameter key="normalized_absolute_error" value="false"/> <parameter key="root_relative_squared_error" value="false"/> <parameter key="squared_error" value="false"/> <parameter key="correlation" value="false"/> <parameter key="squared_correlation" value="false"/> <parameter key="prediction_average" value="false"/> <parameter key="spearman_rho" value="false"/> <parameter key="kendall_tau" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="input 1" to_op="Windowing (Series)" to_port="example set"/> <connect from_op="Set Macro (Real)" from_port="through 1" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Windowing (Series)" from_port="windowed example set" to_op="Deep Learning" to_port="training set"/> <connect from_op="Deep Learning" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Deep Learning" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Retrieve Lake Huron" from_port="output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="10.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.3.001" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="10.3.001" expanded="true" height="68" name="Retrieve Lake Huron" origin="GENERATED_TUTORIAL" width="90" x="112" y="34"> <parameter key="repository_entry" value="//Samples/Time Series/data sets/Lake Huron"/> </operator> <operator activated="true" class="set_macro" compatibility="10.3.001" expanded="true" height="82" name="Set Macro" width="90" x="112" y="238"> <parameter key="macro" value="Winsiz"/> <parameter key="value" value="4"/> </operator> <operator activated="true" class="time_series:process_windows" compatibility="10.3.001" expanded="true" height="103" name="Process Windows" origin="GENERATED_TUTORIAL" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="has_indices" value="true"/> <parameter key="indices_attribute" value="Date"/> <parameter key="sort_time_series" value="false"/> <parameter key="expert_settings" value="false"/> <parameter key="unit" value="example based"/> <parameter key="windows_defined" value="from start"/> <parameter key="custom_start_point" value="5"/> <parameter key="custom_end_point" value="100"/> <parameter key="window_size" value="%{Winsiz}"/> <parameter key="custom_start_time" value="2000-01-01 00:00:00"/> <parameter key="custom_end_time" value="2030-01-01 00:00:00"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="window_size_time" value="1.Hours"/> <parameter key="windows_stop_definition" value="from next window start"/> <parameter key="window_start_attribute" value=""/> <parameter key="window_stop_attribute" value=""/> <parameter key="no_overlapping_windows" value="false"/> <parameter key="step_size" value="1"/> <parameter key="step_size_time" value="1.Minutes"/> <parameter key="create_horizon_(labels)" value="true"/> <parameter key="horizon_attribute" value="Lake surface level / feet"/> <parameter key="horizon_size" value="1"/> <parameter key="horizon_offset" value="0"/> <parameter key="horizon_size_time" value="1.Hours"/> <parameter key="horizon_offset_time" value="0.Minutes"/> <parameter key="horizon_start_attribute" value=""/> <parameter key="horizon_stop_attribute" value=""/> <parameter key="empty_window_handling" value="add empty exampleset"/> <parameter key="add_last_index_in_window_attribute" value="true"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="time_series:extract_std_descriptive_features" compatibility="10.3.001" expanded="true" height="82" name="Extract Aggregates" origin="GENERATED_TUTORIAL" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="sum" value="true"/> <parameter key="mean" value="true"/> <parameter key="geometric_mean" value="true"/> <parameter key="first_quartile" value="true"/> <parameter key="median" value="true"/> <parameter key="third_quartile" value="true"/> <parameter key="min" value="true"/> <parameter key="max" value="true"/> <parameter key="std_deviation" value="true"/> <parameter key="kurtosis" value="true"/> <parameter key="skewness" value="true"/> <parameter key="add_time_series_name" value="false"/> <parameter key="ignore_invalid_values" value="false"/> </operator> <connect from_port="windowed example set" to_op="Extract Aggregates" to_port="example set"/> <connect from_op="Extract Aggregates" from_port="features" to_port="output 1"/> <portSpacing port="source_windowed example set" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="10.3.001" expanded="true" height="82" name="Append" origin="GENERATED_TUTORIAL" width="90" x="514" y="34"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> <parameter key="merge_type" value="all"/> </operator> <connect from_op="Retrieve Lake Huron" from_port="output" to_op="Process Windows" to_port="example set"/> <connect from_op="Set Macro" from_port="through 1" to_op="Process Windows" to_port="custom windows"/> <connect from_op="Process Windows" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
