<?xml version="1.0" encoding="UTF-8"?><process version="10.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.3.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" class="text:process_document_from_file" compatibility="10.0.000" expanded="true" height="82" name="Process Documents from Files" width="90" x="45" y="34"> <list key="text_directories"> <parameter key="positive" value="C:/Users/rjones/Downloads/txt_sentoken/pos_reviews"/> </list> <parameter key="file_pattern" value="*"/> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="UTF-8"/> <parameter key="create_word_vector" value="true"/> <parameter key="vector_creation" value="TF-IDF"/> <parameter key="add_meta_information" value="true"/> <parameter key="keep_text" value="false"/> <parameter key="prune_method" value="none"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_absolute" value="1"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="10.0.000" expanded="true" height="68" name="Tokenize" width="90" x="45" y="34"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <operator activated="true" class="text:transform_cases" compatibility="10.0.000" expanded="true" height="68" name="Transform Cases" width="90" x="179" y="34"> <parameter key="transform_to" value="lower case"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="10.0.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="313" y="34"/> <operator activated="true" class="text:stem_porter" compatibility="10.0.000" expanded="true" height="68" name="Stem (Porter)" width="90" x="447" y="34"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Stem (Porter)" to_port="document"/> <connect from_op="Stem (Porter)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:process_document_from_file" compatibility="10.0.000" expanded="true" height="82" name="Process Documents from Files (2)" width="90" x="45" y="136"> <list key="text_directories"> <parameter key="negative" value="C:/Users/rjones/Downloads/txt_sentoken/neg_reviews"/> </list> <parameter key="file_pattern" value="*"/> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="UTF-8"/> <parameter key="create_word_vector" value="true"/> <parameter key="vector_creation" value="TF-IDF"/> <parameter key="add_meta_information" value="true"/> <parameter key="keep_text" value="false"/> <parameter key="prune_method" value="none"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_absolute" value="1"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="10.0.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="45" y="34"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <operator activated="true" class="text:transform_cases" compatibility="10.0.000" expanded="true" height="68" name="Transform Cases (2)" width="90" x="179" y="34"> <parameter key="transform_to" value="lower case"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="10.0.000" expanded="true" height="68" name="Filter Stopwords (English) (2)" width="90" x="313" y="34"/> <operator activated="true" class="text:stem_porter" compatibility="10.0.000" expanded="true" height="68" name="Stem (Porter) (2)" width="90" x="447" y="34"/> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/> <connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Stopwords (English) (2)" to_port="document"/> <connect from_op="Filter Stopwords (English) (2)" from_port="document" to_op="Stem (Porter) (2)" to_port="document"/> <connect from_op="Stem (Porter) (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="operator_toolbox:advanced_append" compatibility="2.17.000" expanded="true" height="103" name="Append (Superset)" width="90" x="246" y="34"/> <operator activated="true" class="replace_missing_values" compatibility="10.3.001" expanded="true" height="103" name="Replace Missing Values" width="90" x="380" y="34"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="true" class="nominal_to_binominal" compatibility="10.3.001" expanded="true" height="103" name="Nominal to Binominal" width="90" x="514" y="34"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> <parameter key="transform_binominal" value="false"/> <parameter key="use_underscore_in_name" value="false"/> </operator> <operator activated="true" class="support_vector_machine" compatibility="10.3.001" expanded="true" height="124" name="SVM" width="90" x="715" y="34"> <parameter key="kernel_type" value="dot"/> <parameter key="kernel_gamma" value="1.0"/> <parameter key="kernel_sigma1" value="1.0"/> <parameter key="kernel_sigma2" value="0.0"/> <parameter key="kernel_sigma3" value="2.0"/> <parameter key="kernel_shift" value="1.0"/> <parameter key="kernel_degree" value="2.0"/> <parameter key="kernel_a" value="1.0"/> <parameter key="kernel_b" value="0.0"/> <parameter key="kernel_cache" value="200"/> <parameter key="C" value="0.0"/> <parameter key="convergence_epsilon" value="0.001"/> <parameter key="max_iterations" value="100000"/> <parameter key="scale" value="true"/> <parameter key="calculate_weights" value="true"/> <parameter key="return_optimization_performance" value="true"/> <parameter key="L_pos" value="1.0"/> <parameter key="L_neg" value="1.0"/> <parameter key="epsilon" value="0.0"/> <parameter key="epsilon_plus" value="0.0"/> <parameter key="epsilon_minus" value="0.0"/> <parameter key="balance_cost" value="false"/> <parameter key="quadratic_loss_pos" value="false"/> <parameter key="quadratic_loss_neg" value="false"/> <parameter key="estimate_performance" value="false"/> </operator> <operator activated="true" class="text:process_document_from_file" compatibility="10.0.000" expanded="true" height="82" name="Process Documents from Files (3)" width="90" x="447" y="289"> <list key="text_directories"> <parameter key="positive" value="C:/Users/rjones/Downloads/txt_sentoken/test_pos"/> </list> <parameter key="file_pattern" value="*"/> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="UTF-8"/> <parameter key="create_word_vector" value="true"/> <parameter key="vector_creation" value="TF-IDF"/> <parameter key="add_meta_information" value="true"/> <parameter key="keep_text" value="false"/> <parameter key="prune_method" value="none"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_absolute" value="1"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="10.0.000" expanded="true" height="68" name="Tokenize (3)" width="90" x="45" y="34"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <operator activated="true" class="text:transform_cases" compatibility="10.0.000" expanded="true" height="68" name="Transform Cases (3)" width="90" x="179" y="34"> <parameter key="transform_to" value="lower case"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="10.0.000" expanded="true" height="68" name="Filter Stopwords (English) (3)" width="90" x="313" y="34"/> <operator activated="true" class="text:stem_porter" compatibility="10.0.000" expanded="true" height="68" name="Stem (Porter) (3)" width="90" x="447" y="34"/> <connect from_port="document" to_op="Tokenize (3)" to_port="document"/> <connect from_op="Tokenize (3)" from_port="document" to_op="Transform Cases (3)" to_port="document"/> <connect from_op="Transform Cases (3)" from_port="document" to_op="Filter Stopwords (English) (3)" to_port="document"/> <connect from_op="Filter Stopwords (English) (3)" from_port="document" to_op="Stem (Porter) (3)" to_port="document"/> <connect from_op="Stem (Porter) (3)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:process_document_from_file" compatibility="10.0.000" expanded="true" height="82" name="Process Documents from Files (4)" width="90" x="447" y="391"> <list key="text_directories"> <parameter key="negative" value="C:/Users/rjones/Downloads/txt_sentoken/test_neg"/> </list> <parameter key="file_pattern" value="*"/> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="UTF-8"/> <parameter key="create_word_vector" value="true"/> <parameter key="vector_creation" value="TF-IDF"/> <parameter key="add_meta_information" value="true"/> <parameter key="keep_text" value="false"/> <parameter key="prune_method" value="none"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_absolute" value="1"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="10.0.000" expanded="true" height="68" name="Tokenize (4)" width="90" x="45" y="34"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <operator activated="true" class="text:transform_cases" compatibility="10.0.000" expanded="true" height="68" name="Transform Cases (4)" width="90" x="179" y="34"> <parameter key="transform_to" value="lower case"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="10.0.000" expanded="true" height="68" name="Filter Stopwords (English) (4)" width="90" x="313" y="34"/> <operator activated="true" class="text:stem_porter" compatibility="10.0.000" expanded="true" height="68" name="Stem (Porter) (4)" width="90" x="447" y="34"/> <connect from_port="document" to_op="Tokenize (4)" to_port="document"/> <connect from_op="Tokenize (4)" from_port="document" to_op="Transform Cases (4)" to_port="document"/> <connect from_op="Transform Cases (4)" from_port="document" to_op="Filter Stopwords (English) (4)" to_port="document"/> <connect from_op="Filter Stopwords (English) (4)" from_port="document" to_op="Stem (Porter) (4)" to_port="document"/> <connect from_op="Stem (Porter) (4)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="operator_toolbox:advanced_append" compatibility="2.17.000" expanded="true" height="103" name="Append (Superset) (2)" width="90" x="581" y="289"/> <operator activated="true" class="replace_missing_values" compatibility="10.3.001" expanded="true" height="103" name="Replace Missing Values (2)" width="90" x="715" y="289"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="true" class="apply_model" compatibility="10.3.001" expanded="true" height="82" name="Apply Model" width="90" x="782" y="187"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="10.3.001" expanded="true" height="82" name="Performance" width="90" x="916" y="187"> <parameter key="manually_set_positive_class" value="false"/> <parameter key="main_criterion" value="first"/> <parameter key="accuracy" value="true"/> <parameter key="classification_error" value="true"/> <parameter key="kappa" value="false"/> <parameter key="AUC (optimistic)" value="false"/> <parameter key="AUC" value="true"/> <parameter key="AUC (pessimistic)" value="false"/> <parameter key="precision" value="false"/> <parameter key="recall" value="false"/> <parameter key="lift" value="false"/> <parameter key="fallout" value="false"/> <parameter key="f_measure" value="false"/> <parameter key="false_positive" value="false"/> <parameter key="false_negative" value="false"/> <parameter key="true_positive" value="false"/> <parameter key="true_negative" value="false"/> <parameter key="sensitivity" value="false"/> <parameter key="specificity" value="false"/> <parameter key="youden" value="false"/> <parameter key="positive_predictive_value" value="false"/> <parameter key="negative_predictive_value" value="false"/> <parameter key="psep" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <connect from_op="Process Documents from Files" from_port="example set" to_op="Append (Superset)" to_port="example set 1"/> <connect from_op="Process Documents from Files" from_port="word list" to_op="Process Documents from Files (3)" to_port="word list"/> <connect from_op="Process Documents from Files (2)" from_port="example set" to_op="Append (Superset)" to_port="example set 2"/> <connect from_op="Process Documents from Files (2)" from_port="word list" to_op="Process Documents from Files (4)" to_port="word list"/> <connect from_op="Append (Superset)" from_port="merged set" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Process Documents from Files (3)" from_port="example set" to_op="Append (Superset) (2)" to_port="example set 1"/> <connect from_op="Process Documents from Files (4)" from_port="example set" to_op="Append (Superset) (2)" to_port="example set 2"/> <connect from_op="Append (Superset) (2)" from_port="merged set" to_op="Replace Missing Values (2)" to_port="example set input"/> <connect from_op="Replace Missing Values (2)" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
