Hi there:
I'm a newcomer here. I really need some help about polynomial regression.
This is the data I've given to polynomial regression.
| x |
y |
| -100 |
30208 |
| -99 |
29609 |
| -98 |
29016 |
| -97 |
28429 |
| -96 |
27848 |
| -95 |
27273 |
| -94 |
26704 |
| -93 |
26141 |
| -92 |
25584 |
| -91 |
25033 |
| -90 |
24488 |
| -89 |
23949 |
| -88 |
23416 |
| -87 |
22889 |
| -86 |
22368 |
| -85 |
21853 |
| -84 |
21344 |
| -83 |
20841 |
| -82 |
20344 |
| -81 |
19853 |
| -80 |
19368 |
| -79 |
18889 |
| -78 |
18416 |
| -77 |
17949 |
| -76 |
17488 |
| -75 |
17033 |
| -74 |
16584 |
| -73 |
16141 |
| -72 |
15704 |
| -71 |
15273 |
| -70 |
14848 |
| -69 |
14429 |
| -68 |
14016 |
| -67 |
13609 |
| -66 |
13208 |
| -65 |
12813 |
| -64 |
12424 |
| -63 |
12041 |
| -62 |
11664 |
| -61 |
11293 |
| -60 |
10928 |
| -59 |
10569 |
| -58 |
10216 |
| -57 |
9869 |
| -56 |
9528 |
| -55 |
9193 |
| -54 |
8864 |
| -53 |
8541 |
| -52 |
8224 |
| -51 |
7913 |
| -50 |
7608 |
| -49 |
7309 |
| -48 |
7016 |
| -47 |
6729 |
| -46 |
6448 |
| -45 |
6173 |
| -44 |
5904 |
| -43 |
5641 |
| -42 |
5384 |
| -41 |
5133 |
| -40 |
4888 |
| -39 |
4649 |
| -38 |
4416 |
| -37 |
4189 |
| -36 |
3968 |
| -35 |
3753 |
| -34 |
3544 |
| -33 |
3341 |
| -32 |
3144 |
| -31 |
2953 |
| -30 |
2768 |
| -29 |
2589 |
| -28 |
2416 |
| -27 |
2249 |
| -26 |
2088 |
| -25 |
1933 |
| -24 |
1784 |
| -23 |
1641 |
| -22 |
1504 |
| -21 |
1373 |
| -20 |
1248 |
| -19 |
1129 |
| -18 |
1016 |
| -17 |
909 |
| -16 |
808 |
| -15 |
713 |
| -14 |
624 |
| -13 |
541 |
| -12 |
464 |
| -11 |
393 |
| -10 |
328 |
| -9 |
269 |
| -8 |
216 |
| -7 |
169 |
| -6 |
128 |
| -5 |
93 |
| -4 |
64 |
| -3 |
41 |
| -2 |
24 |
| -1 |
13 |
| 0 |
8 |
| 1 |
9 |
| 2 |
16 |
| 3 |
29 |
| 4 |
48 |
| 5 |
73 |
| 6 |
104 |
| 7 |
141 |
| 8 |
184 |
| 9 |
233 |
| 10 |
288 |
| 11 |
349 |
| 12 |
416 |
| 13 |
489 |
| 14 |
568 |
| 15 |
653 |
| 16 |
744 |
| 17 |
841 |
| 18 |
944 |
| 19 |
1053 |
| 20 |
1168 |
| 21 |
1289 |
| 22 |
1416 |
| 23 |
1549 |
| 24 |
1688 |
| 25 |
1833 |
| 26 |
1984 |
| 27 |
2141 |
| 28 |
2304 |
| 29 |
2473 |
| 30 |
2648 |
| 31 |
2829 |
| 32 |
3016 |
| 33 |
3209 |
| 34 |
3408 |
| 35 |
3613 |
| 36 |
3824 |
| 37 |
4041 |
| 38 |
4264 |
| 39 |
4493 |
| 40 |
4728 |
| 41 |
4969 |
| 42 |
5216 |
| 43 |
5469 |
| 44 |
5728 |
| 45 |
5993 |
| 46 |
6264 |
| 47 |
6541 |
| 48 |
6824 |
| 49 |
7113 |
| 50 |
7408 |
| 51 |
7709 |
| 52 |
8016 |
| 53 |
8329 |
| 54 |
8648 |
| 55 |
8973 |
| 56 |
9304 |
| 57 |
9641 |
| 58 |
9984 |
| 59 |
10333 |
| 60 |
10688 |
| 61 |
11049 |
| 62 |
11416 |
| 63 |
11789 |
| 64 |
12168 |
| 65 |
12553 |
| 66 |
12944 |
| 67 |
13341 |
| 68 |
13744 |
| 69 |
14153 |
| 70 |
14568 |
| 71 |
14989 |
| 72 |
15416 |
| 73 |
15849 |
| 74 |
16288 |
| 75 |
16733 |
| 76 |
17184 |
| 77 |
17641 |
| 78 |
18104 |
| 79 |
18573 |
| 80 |
19048 |
| 81 |
19529 |
| 82 |
20016 |
| 83 |
20509 |
| 84 |
21008 |
| 85 |
21513 |
| 86 |
22024 |
| 87 |
22541 |
| 88 |
23064 |
| 89 |
23593 |
| 90 |
24128 |
| 91 |
24669 |
| 92 |
25216 |
| 93 |
25769 |
| 94 |
26328 |
| 95 |
26893 |
| 96 |
27464 |
| 97 |
28041 |
| 98 |
28624 |
| 99 |
29213 |
| 100 |
29808 |
201 data,the relationship of x and y is :y=3*x^2-2*x+8
And this what I got from polynomial regression:
2.998 * x ^ 2.000
+ 22.316
Really confused, please help me.
<?xml version="1.0" encoding="UTF-8"?><process version="10.3.001">
<operator activated="true" class="read_excel" compatibility="10.3.001" expanded="true" height="68" name="Read Excel" width="90" x="45" y="442">
<parameter key="excel_file" value="C:\Users\Administrator\Desktop\test1.xlsx"/>
<parameter key="sheet_selection" value="sheet number"/>
<parameter key="sheet_number" value="1"/>
<parameter key="imported_cell_range" value="A1"/>
<parameter key="use_header_row" value="true"/>
<parameter key="header_row" value="1"/>
<parameter key="first_row_as_names" value="true"/>
<list key="annotations"/>
<parameter key="date_format" value=""/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="英文 (美国)"/>
<parameter key="read_all_values_as_polynominal" value="false"/>
<parameter key="0" value="x.true.integer.attribute"/>
<parameter key="1" value="y.true.integer.attribute"/>
</list>
<parameter key="read_not_matching_values_as_missings" value="false"/>
</process>
<operator activated="true" class="blending:select_attributes" compatibility="10.3.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="442">
<parameter key="type" value="include attributes"/>
<parameter key="attribute_filter_type" value="a subset"/>
<parameter key="select_attribute" value=""/>
<parameter key="select_subset" value="x␞y"/>
<parameter key="also_apply_to_special_attributes_(id,_label..)" value="true"/>
</process>
<operator activated="true" class="blending:set_role" compatibility="10.3.001" expanded="true" height="82" name="Set Role" width="90" x="313" y="442">
<list key="set_roles">
<parameter key="y" value="label"/>
</list>
</process>
<operator activated="true" class="split_data" compatibility="10.1.003" expanded="true" height="82" name="Split Data" origin="GENERATED_TUTORIAL" width="90" x="715" y="85">
<enumeration key="partitions">
<parameter key="ratio" value="0.7"/>
<parameter key="ratio" value="0.3"/>
</enumeration>
<parameter key="sampling_type" value="automatic"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
</process>
<operator activated="true" class="polynomial_regression" compatibility="10.3.001" expanded="true" height="82" name="Polynomial Regression" width="90" x="849" y="85">
<parameter key="max_iterations" value="5000"/>
<parameter key="replication_factor" value="1"/>
<parameter key="max_degree" value="5"/>
<parameter key="min_coefficient" value="-100.0"/>
<parameter key="max_coefficient" value="100.0"/>
</process>
