is there any way to create to properties for the imported beam_sections Pbar card image
the id number is maintained properly,
i have manually done for some values, in actual model there is a lot of values
a sample file hm file is attached for better understanding.
and test.hm file is shared, where properties needs to be created.
try this script:
*createmark beamsects 1 all foreach bsId [hm_getmark beamsects 1] { set dim1 [hm_getentityvalue beamsects $bsId beamsect_dim1 0 -byid] set prop_name dia_[string trimright [format %.3f [expr 2*$dim1]] 0] *collectorcreateonly properties "$prop_name" "" 11 *createmark properties 2 -1 set prop_id [hm_getmark props 2] *dictionaryload properties 2 "[hm_info templatefilename]" "PBAR" *attributeupdateentity properties $prop_id 3179 1 2 0 beamsects $bsId *attributeupdateint properties $prop_id 3240 1 2 0 1 *attributeupdatedouble properties $prop_id 72 1 2 0 0 *attributeupdatestring properties $prop_id 130 1 0 0 "" *attributeupdateint properties $prop_id 108 1 2 0 0 *attributeupdateint properties $prop_id 3899 1 2 0 0 }
Tested on HM2019
I was going to recommend matrix browser route but script is easier!
Hi, try this script: *createmark beamsects 1 all foreach bsId [hm_getmark beamsects 1] { set dim1 [hm_getentityvalue beamsects $bsId beamsect_dim1 0 -byid] set prop_name dia_[string trimright [format %.3f [expr 2*$dim1]] 0] *collectorcreateonly properties "$prop_name" "" 11 *createmark properties 2 -1 set prop_id [hm_getmark props 2] *dictionaryload properties 2 "[hm_info templatefilename]" "PBAR" *attributeupdateentity properties $prop_id 3179 1 2 0 beamsects $bsId *attributeupdateint properties $prop_id 3240 1 2 0 1 *attributeupdatedouble properties $prop_id 72 1 2 0 0 *attributeupdatestring properties $prop_id 130 1 0 0 "" *attributeupdateint properties $prop_id 108 1 2 0 0 *attributeupdateint properties $prop_id 3899 1 2 0 0 } Tested on HM2019
thank you sir,
it helped alot and saved a lot of time.
