Hello together,
I try to simulate a simple transmission line system with and without a ground plane to verify the MTL theory.
To do so, I need to define current sources and load resistors at both ends of each line, as it is required for MTL theory.
But in the network schematic I can't use loads and sources. I do not want to construct wires from the MTL endings to the ground plane, since they generate additional crosstalk.
How would you do that? I tried to use cables and wires, but both solutions seem to be not sufficient.
Maybe someone knows how to do that. I would be happy to know.
Best regards
