<?xml version="1.0" encoding="UTF-8"?><process version="10.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.3.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="10.3.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="179" y="136"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="Age,GEnder,Floor 11,Male,20 11,Female,29 13,Male,18 12,Male,17"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="blending:generate_id" compatibility="10.3.001" expanded="true" height="82" name="Generate ID" width="90" x="313" y="136"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="filter_examples" compatibility="10.3.001" expanded="true" height="103" name="Filter Examples" width="90" x="447" y="187"> <parameter key="parameter_expression" value=""/> <parameter key="condition_class" value="custom_filters"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"> <parameter key="filters_entry_key" value="id.eq.2"/> </list> <parameter key="filters_logic_and" value="true"/> <parameter key="filters_check_metadata" value="true"/> </operator> <operator activated="true" class="map" compatibility="10.3.001" expanded="true" height="82" name="Map" width="90" x="581" y="136"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Age"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <list key="value_mappings"/> <parameter key="replace_what" value="11"/> <parameter key="replace_by" value="12"/> <parameter key="consider_regular_expressions" value="false"/> <parameter key="add_default_mapping" value="false"/> </operator> <operator activated="true" class="append" compatibility="10.3.001" expanded="true" height="103" name="Append" width="90" x="715" y="136"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> <parameter key="merge_type" value="all"/> </operator> <operator activated="true" class="blending:sort" compatibility="10.3.001" expanded="true" height="82" name="Sort" width="90" x="849" y="136"> <list key="sort_by"> <parameter key="id" value="ascending"/> </list> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Map" to_port="example set input"/> <connect from_op="Filter Examples" from_port="unmatched example set" to_op="Append" to_port="example set 2"/> <connect from_op="Map" from_port="example set output" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
