<context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.3.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="web:crawl_web" compatibility="10.0.000" expanded="true" height="68" name="Crawl Web 5.X" width="90" x="246" y="187"> <parameter key="url" value="https://altair.com/"/> <list key="crawling_rules"/> <parameter key="write_pages_into_files" value="true"/> <parameter key="add_pages_as_attribute" value="false"/> <parameter key="output_dir" value="C:/"/> <parameter key="extension" value="txt"/> <parameter key="max_pages" value="100"/> <parameter key="max_depth" value="1"/> <parameter key="domain" value="server"/> <parameter key="delay" value="1000"/> <parameter key="max_threads" value="1"/> <parameter key="max_page_size" value="500"/> <parameter key="user_agent" value="rapid-miner-crawler"/> <parameter key="obey_robot_exclusion" value="true"/> <parameter key="really_ignore_exclusion" value="false"/> </operator> <connect from_op="Crawl Web 5.X" from_port="Example Set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
