<?xml version="1.0" encoding="UTF-8"?><process version="10.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.3.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="operator_toolbox:caching_subprocess" compatibility="2.17.000" expanded="true" height="103" name="Subprocess (Caching)" width="90" x="179" y="34"> <parameter key="caching_strategy" value="auto"/> <parameter key="cache_uuid" value="f03bf32c-0bdc-4273-903f-04149c6f2f6f"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="10.3.000" expanded="true" height="68" name="Retrieve Balanced dataset" width="90" x="447" y="85"> <parameter key="repository_entry" value="Balanced dataset"/> </operator> <operator activated="true" class="subprocess" compatibility="10.3.000" expanded="true" height="82" name="Pre-process data (2)" width="90" x="715" y="85"> <process expanded="true"> <operator activated="true" class="blending:select_attributes" compatibility="10.3.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="45" y="34"> <parameter key="type" value="include attributes"/> <parameter key="attribute_filter_type" value="a subset"/> <parameter key="select_attribute" value=""/> <parameter key="select_subset" value="Location␞Review␞Univeristy Name"/> <parameter key="also_apply_to_special_attributes_(id,_label..)" value="false"/> </operator> <operator activated="true" class="filter_examples" compatibility="10.3.000" expanded="true" height="103" name="Filter Examples (2)" width="90" x="179" y="34"> <parameter key="parameter_expression" value=""/> <parameter key="condition_class" value="custom_filters"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"> <parameter key="filters_entry_key" value="Univeristy Name.is_not_missing."/> <parameter key="filters_entry_key" value="Review.is_not_missing."/> <parameter key="filters_entry_key" value="Location.is_not_missing."/> </list> <parameter key="filters_logic_and" value="true"/> <parameter key="filters_check_metadata" value="true"/> </operator> <operator activated="true" class="operator_toolbox:extract_sentiment" compatibility="2.17.000" expanded="true" height="103" name="Extract Sentiment (2)" width="90" x="313" y="34"> <parameter key="model" value="vader"/> <parameter key="text_attribute" value="Review"/> <parameter key="show_advanced_output" value="false"/> <parameter key="use_default_tokenization_regex" value="true"/> <list key="additional_words"/> </operator> <operator activated="true" class="nominal_to_text" compatibility="10.3.000" expanded="true" height="82" name="Nominal to Text (3)" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <connect from_port="in 1" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Filter Examples (2)" to_port="example set input"/> <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Extract Sentiment (2)" to_port="exa"/> <connect from_op="Extract Sentiment (2)" from_port="exa" to_op="Nominal to Text (3)" to_port="example set input"/> <connect from_op="Nominal to Text (3)" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="blending:generate_columns" compatibility="10.3.000" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="849" y="85"> <list key="function_descriptions"> <parameter key="Sentiment" value="if([Score]>0,"positive",if([Score]<0,"negative","neutral"))"/> </list> <parameter key="keep_all_columns" value="true"/> </operator> <operator activated="true" class="blending:set_role" compatibility="10.3.000" expanded="true" height="82" name="Set Role (3)" width="90" x="1117" y="85"> <list key="set_roles"> <parameter key="Sentiment" value="label"/> </list> </operator> <operator activated="true" class="nominal_to_text" compatibility="10.3.000" expanded="true" height="82" name="Nominal to Text (4)" width="90" x="1251" y="85"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="blending:set_role" compatibility="10.3.000" expanded="true" height="82" name="Set Role (4)" width="90" x="1385" y="85"> <list key="set_roles"> <parameter key="Univeristy Name" value="id"/> </list> </operator> <operator activated="true" class="operator_toolbox:smote" compatibility="2.17.000" expanded="true" height="82" name="SMOTE Upsampling (2)" width="90" x="1519" y="85"> <parameter key="number_of_neighbours" value="5"/> <parameter key="normalize" value="true"/> <parameter key="equalize_classes" value="true"/> <parameter key="upsampling_size" value="1000"/> <parameter key="auto_detect_minority_class" value="true"/> <parameter key="round_integers" value="true"/> <parameter key="nominal_change_rate" value="0.5"/> <parameter key="append_to_original" value="true"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="10.0.000" expanded="true" height="82" name="Process Documents from Data (2)" width="90" x="1653" y="85"> <parameter key="create_word_vector" value="true"/> <parameter key="vector_creation" value="TF-IDF"/> <parameter key="add_meta_information" value="true"/> <parameter key="keep_text" value="false"/> <parameter key="prune_method" value="none"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <parameter key="select_attributes_and_weights" value="false"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="10.0.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="45" y="34"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <operator activated="true" class="text:transform_cases" compatibility="10.0.000" expanded="true" height="68" name="Transform Cases (2)" width="90" x="179" y="34"> <parameter key="transform_to" value="lower case"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="10.0.000" expanded="true" height="68" name="Filter Stopwords (English) (2)" width="90" x="380" y="34"/> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/> <connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Stopwords (English) (2)" to_port="document"/> <connect from_op="Filter Stopwords (English) (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve Balanced dataset" from_port="output" to_op="Pre-process data (2)" to_port="in 1"/> <connect from_op="Pre-process data (2)" from_port="out 1" to_op="Generate Attributes (2)" to_port="table input"/> <connect from_op="Generate Attributes (2)" from_port="table output" to_op="Set Role (3)" to_port="example set input"/> <connect from_op="Set Role (3)" from_port="example set output" to_op="Nominal to Text (4)" to_port="example set input"/> <connect from_op="Nominal to Text (4)" from_port="example set output" to_op="Set Role (4)" to_port="example set input"/> <connect from_op="Set Role (4)" from_port="example set output" to_op="SMOTE Upsampling (2)" to_port="exa"/> <connect from_op="SMOTE Upsampling (2)" from_port="ups" to_op="Process Documents from Data (2)" to_port="example set"/> <connect from_op="Process Documents from Data (2)" from_port="example set" to_port="out 1"/> <connect from_op="Process Documents from Data (2)" from_port="word list" to_port="out 2"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> <portSpacing port="sink_out 3" spacing="0"/> </process> </operator> <operator activated="true" class="declare_missing_value" compatibility="10.3.000" expanded="true" height="82" name="Declare Missing Value" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="mode" value="numeric"/> <parameter key="numeric_value" value="0.0"/> <parameter key="expression_value" value=""/> </operator> <operator activated="true" class="aggregate" compatibility="10.3.000" expanded="true" height="82" name="Aggregate" width="90" x="447" y="34"> <parameter key="use_default_aggregation" value="true"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="count (ignoring missings)"/> <list key="aggregation_attributes"/> <parameter key="group_by_attributes" value="|Univeristy Name|Sentiment"/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="10.3.000" expanded="true" height="82" name="Rename by Replacing" width="90" x="581" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="countWithOutMissings\((.*?)\)"/> <parameter key="replace_by" value="$1"/> </operator> <connect from_op="Subprocess (Caching)" from_port="out 1" to_op="Declare Missing Value" to_port="example set input"/> <connect from_op="Subprocess (Caching)" from_port="out 2" to_port="result 1"/> <connect from_op="Declare Missing Value" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
