Dear All
I am running the following loop to go through multi-labels and write the outputs into Excel file each time. The macro I am using %{a}.xlsx just writes each Excel file name based on numbers (1.xlxs, 2.xlxs, ...). I want to change this macro to write down the name of each label. I mean the Excel outputs will be the name of first lable.xlxs, second label.xlxs, ...).
Thanks
<?xml version="1.0" encoding="UTF-8"?><process version="10.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="10.3.000" expanded="true" name="Process" origin="GENERATED_TUTORIAL">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="10.3.000" expanded="true" height="68" name="Retrieve Quartiled All data" width="90" x="45" y="85">
<parameter key="repository_entry" value="Quartiled All data"/>
<operator activated="true" class="blending:set_role" compatibility="10.3.000" expanded="true" height="82" name="Set Role (2)" origin="GENERATED_TUTORIAL" width="90" x="179" y="85">
<list key="set_roles">
<parameter key="Hardness Bite 1 (N)" value="label"/>
<parameter key="Hardness Bite 2 (N)" value="label"/>
<parameter key="Adhesive Force (N)" value="label"/>
<parameter key="Cohesiveness" value="label"/>
<parameter key="Gumminess (N)" value="label"/>
<parameter key="Springiness (mm)" value="label"/>
<parameter key="Chewiness (N)" value="label"/>
<parameter key="Resilience" value="label"/>
<parameter key="gas amount (mol/g)" value="label"/>
<parameter key="baking loss" value="label"/>
<parameter key="Crust Colour a*" value="label"/>
<parameter key="Crust Colour b*" value="label"/>
<parameter key="Crust Colour L*" value="label"/>
<parameter key="Crust ^E*" value="label"/>
<parameter key="Crumb ^E*" value="label"/>
<parameter key="Crumb Colour a*" value="label"/>
<parameter key="Crumb Colour b*" value="label"/>
<parameter key="Crumb Colour L*" value="label"/>
<parameter key="void_fraction" value="label"/>
<parameter key="mean_area_mm2" value="label"/>
<parameter key="cell_density_cm2" value="label"/>
<parameter key="small_cell_density_cm2" value="label"/>
<parameter key="large_cell_density_cm2" value="label"/>
<parameter key="range" value="label"/>
<parameter key="mean_ecc" value="label"/>
</list>
<operator activated="true" class="loop_labels" compatibility="10.3.000" expanded="true" height="82" name="Loop Labels" origin="GENERATED_TUTORIAL" width="90" x="313" y="85">
<operator activated="true" class="replace_missing_values" compatibility="10.3.000" expanded="true" height="103" name="Replace Missing Values (4)" width="90" x="45" y="34">
<parameter key="return_preprocessing_model" value="false"/>
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="default" value="average"/>
<list key="columns"/>
<operator activated="true" class="select_attributes" compatibility="10.3.000" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34">
<parameter key="attribute" value="SCC"/>
<parameter key="attributes" value="|au_scc|Vol|Prot|Peak_Flow|Milking_Time|Lact|Fat|EC|Date"/>
<parameter key="value_type" value="numeric"/>
<operator activated="true" class="weight_by_information_gain" compatibility="10.3.000" expanded="true" height="82" name="Weight by Information Gain" width="90" x="313" y="21">
<parameter key="normalize_weights" value="true"/>
<parameter key="sort_weights" value="true"/>
<parameter key="sort_direction" value="ascending"/>
<operator activated="true" class="weights_to_data" compatibility="10.3.000" expanded="true" height="68" name="Weights to Data" width="90" x="447" y="34"/>
<operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="82" name="Set Role" width="90" x="581" y="34">
<parameter key="attribute_name" value="Attribute"/>
<operator activated="true" class="rename" compatibility="10.3.000" expanded="true" height="82" name="Rename" width="90" x="715" y="34">
<parameter key="old_name" value="Weight"/>
<parameter key="new_name" value="Weight_Info Gain"/>
<list key="rename_additional_attributes"/>
<operator activated="true" class="write_excel" compatibility="10.3.000" expanded="true" height="103" name="Write Excel" width="90" x="849" y="34">
<parameter key="excel_file" value="/Users/Mansour/Downloads/Maman_Mona/%{a}.xlsx"/>
<parameter key="file_format" value="xlsx"/>
<enumeration key="sheet_names"/>
<parameter key="sheet_name" value="RapidMiner Data"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="number_format" value="#.0"/>
<connect from_port="example set" to_op="Replace Missing Values (4)" to_port="example set input"/>
<connect from_op="Replace Missing Values (4)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Weight by Information Gain" to_port="example set"/>
<connect from_op="Weight by Information Gain" from_port="weights" to_op="Weights to Data" to_port="attribute weights"/>
<connect from_op="Weights to Data" from_port="example set" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Rename" to_port="example set input"/>
<connect from_op="Rename" from_port="example set output" to_op="Write Excel" to_port="input"/>
<connect from_op="Write Excel" from_port="through" to_port="out 1"/>
</process>
<connect from_op="Retrieve Quartiled All data" from_port="output" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Loop Labels" to_port="example set"/>
<connect from_op="Loop Labels" from_port="out 1" to_port="result 1"/>
<portSpacing port="sink_result 1" spacing="90"/>
</process>
</process>
