what is the problem?
mansour
New Altair Community Member
Hi
When running a process, it suggests checking the log file below, but I cannot find the issue. Any thoughts?
Nov 6, 2023 11:13:06 PM INFO: Async: Basic browser setup test starting.
Nov 6, 2023 11:13:10 PM INFO: Async: Created basic browser instance.
Nov 6, 2023 11:13:10 PM INFO: Async: Loaded basic browser test content. Executing functionality check.
Nov 6, 2023 11:13:10 PM INFO: Async: Basic browser setup test successful.
Nov 6, 2023 11:13:10 PM INFO: Global Search category actions registered.
Nov 6, 2023 11:13:10 PM INFO: Async: Hardware accelerated browser setup test starting.
Nov 6, 2023 11:13:11 PM INFO: Async: Created hardware accelerated browser instance.
Nov 6, 2023 11:13:11 PM INFO: Async: Loaded hardware accelerated browser test content. Executing functionality check.
Nov 6, 2023 11:13:11 PM INFO: Async: Hardware accelerated browser setup test successful.
Nov 6, 2023 11:13:19 PM INFO: Community repository 'Training Resources' added.
Nov 6, 2023 11:13:19 PM INFO: Community repository 'Community Samples' added.
Nov 6, 2023 11:13:19 PM SEVERE: Cannot create temp directory - potentially deleted. Need to create a new one.
Nov 6, 2023 11:13:24 PM WARNING: Failed to load recent data entries.
Nov 6, 2023 11:13:25 PM INFO: Global Search category academy registered.
Nov 6, 2023 11:13:25 PM INFO: Global Search GUI provider added for category academy.
Nov 6, 2023 11:13:25 PM WARNING: Not adding legacy connections menu even though legacy configurables are present. Check log for offending extensions
Nov 6, 2023 11:13:33 PM INFO: Global Search GUI provider added for category operator.
Nov 6, 2023 11:13:33 PM INFO: Global Search GUI provider added for category repository.
Nov 6, 2023 11:13:33 PM INFO: Global Search GUI provider added for category actions.
Nov 6, 2023 11:13:33 PM INFO: Global Search category marketplace registered.
Nov 6, 2023 11:13:33 PM INFO: Global Search GUI provider added for category marketplace.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Replace Missing Values' was created with version '5.2.000'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Set Role' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Set Role (3)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Set Role (4)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Set Role (5)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Set Role (6)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Set Role (7)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Set Role (8)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Weight by Relief' was created with version '10.1.003'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Set Role (9)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Join' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Join (2)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Join (3)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Join (4)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Join (5)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Join (6)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Join (7)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Set Role (10)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Join (8)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Weight by PCA' was created with version '9.4.001'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Set Role (11)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:08 PM INFO: Operator 'Join (9)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Replace Missing Values' was created with version '5.2.000'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Set Role' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Set Role (3)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Set Role (4)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Set Role (5)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Set Role (6)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Set Role (7)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Set Role (8)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Weight by Relief' was created with version '10.1.003'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Set Role (9)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Join' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Join (2)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Join (3)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Join (4)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Join (5)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Join (6)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Join (7)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Set Role (10)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Join (8)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Weight by PCA' was created with version '9.4.001'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Set Role (11)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:13 PM INFO: Operator 'Join (9)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Replace Missing Values' was created with version '5.2.000'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Set Role' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Set Role (3)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Set Role (4)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Set Role (5)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Set Role (6)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Set Role (7)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Set Role (8)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Weight by Relief' was created with version '10.1.003'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Set Role (9)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Join' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Join (2)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Join (3)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Join (4)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Join (5)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Join (6)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Join (7)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Set Role (10)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Join (8)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Weight by PCA' was created with version '9.4.001'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Set Role (11)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:25 PM INFO: Operator 'Join (9)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:28 PM INFO: No filename given for result file, using stdout for logging results!
Nov 6, 2023 11:17:28 PM INFO: Process //Mona/Loop Label starts
Nov 6, 2023 11:17:29 PM INFO: Set Role (2): Breakpoint reached.
Nov 6, 2023 11:17:32 PM SEVERE: Process failed: operator cannot be executed (Index 0 out of bounds for length 0). Check the log messages...
Nov 6, 2023 11:17:32 PM SEVERE: Here:
Nov 6, 2023 11:17:32 PM SEVERE: Process[1] (Process)
Nov 6, 2023 11:17:32 PM SEVERE: subprocess 'Main Process'
Nov 6, 2023 11:17:32 PM SEVERE: +- Retrieve Quartiled All data[1] (Retrieve)
Nov 6, 2023 11:17:32 PM SEVERE: +- Set Role (2)[1] (Set Role)
Nov 6, 2023 11:17:32 PM SEVERE: +- Loop Labels[1] (Loop Labels)
Nov 6, 2023 11:17:32 PM SEVERE: subprocess 'Iteration'
Nov 6, 2023 11:17:32 PM SEVERE: +- Set Macro[0] (Set Macro)
Nov 6, 2023 11:17:32 PM SEVERE: +- Loop Labels (2)[0] (Loop Labels)
Nov 6, 2023 11:17:32 PM SEVERE: | +- Write Excel (2)[0] (Write Excel)
Nov 6, 2023 11:17:32 PM SEVERE: | +- Generate Macro[0] (Generate Macro)
Nov 6, 2023 11:17:32 PM SEVERE: +- Replace Missing Values (4)[1] (Replace Missing Values)
Nov 6, 2023 11:17:32 PM SEVERE: +- Select Attributes[1] (Select Attributes)
Nov 6, 2023 11:17:32 PM SEVERE: +- Replace Missing Values[1] (Replace Missing Values)
Nov 6, 2023 11:17:32 PM SEVERE: +- Multiply[1] (Multiply)
Nov 6, 2023 11:17:32 PM SEVERE: +- Replace Missing Values (5)[1] (Replace Missing Values)
Nov 6, 2023 11:17:32 PM SEVERE: ==> +- Weight by Information Gain[1] (Weight by Information Gain)
Nov 6, 2023 11:17:32 PM SEVERE: +- Weights to Data[0] (Weights to Data)
Nov 6, 2023 11:17:32 PM SEVERE: +- Set Role[0] (Set Role)
Nov 6, 2023 11:17:32 PM SEVERE: +- Rename[0] (Rename (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Weight by Information Gain Ratio[0] (Weight by Information Gain Ratio)
Nov 6, 2023 11:17:32 PM SEVERE: +- Weights to Data (2)[0] (Weights to Data)
Nov 6, 2023 11:17:32 PM SEVERE: +- Set Role (3)[0] (Set Role)
Nov 6, 2023 11:17:32 PM SEVERE: +- Rename (2)[0] (Rename (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Weight by Rule[0] (Weight by Rule)
Nov 6, 2023 11:17:32 PM SEVERE: +- Weights to Data (3)[0] (Weights to Data)
Nov 6, 2023 11:17:32 PM SEVERE: +- Set Role (4)[0] (Set Role)
Nov 6, 2023 11:17:32 PM SEVERE: +- Rename (3)[0] (Rename (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Weight by Deviation[0] (Weight by Deviation)
Nov 6, 2023 11:17:32 PM SEVERE: +- Weights to Data (4)[0] (Weights to Data)
Nov 6, 2023 11:17:32 PM SEVERE: +- Set Role (5)[0] (Set Role)
Nov 6, 2023 11:17:32 PM SEVERE: +- Rename (4)[0] (Rename (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Weight by Chi Squared Statistic[0] (Weight by Chi Squared Statistic)
Nov 6, 2023 11:17:32 PM SEVERE: +- Weights to Data (5)[0] (Weights to Data)
Nov 6, 2023 11:17:32 PM SEVERE: +- Set Role (6)[0] (Set Role)
Nov 6, 2023 11:17:32 PM SEVERE: +- Rename (5)[0] (Rename (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Weight by Gini Index[0] (Weight by Gini Index)
Nov 6, 2023 11:17:32 PM SEVERE: +- Weights to Data (6)[0] (Weights to Data)
Nov 6, 2023 11:17:32 PM SEVERE: +- Set Role (7)[0] (Set Role)
Nov 6, 2023 11:17:32 PM SEVERE: +- Rename (6)[0] (Rename (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Weight by Uncertainty[0] (Weight by Uncertainty)
Nov 6, 2023 11:17:32 PM SEVERE: +- Weights to Data (7)[0] (Weights to Data)
Nov 6, 2023 11:17:32 PM SEVERE: +- Set Role (8)[0] (Set Role)
Nov 6, 2023 11:17:32 PM SEVERE: +- Rename (7)[0] (Rename (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Weight by Relief[0] (Weight by Relief)
Nov 6, 2023 11:17:32 PM SEVERE: +- Weights to Data (8)[0] (Weights to Data)
Nov 6, 2023 11:17:32 PM SEVERE: +- Set Role (9)[0] (Set Role)
Nov 6, 2023 11:17:32 PM SEVERE: +- Rename (8)[0] (Rename (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Join[0] (Join (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Join (2)[0] (Join (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Join (3)[0] (Join (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Join (4)[0] (Join (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Join (5)[0] (Join (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Join (6)[0] (Join (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Join (7)[0] (Join (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Replace Missing Values (2)[0] (Replace Missing Values)
Nov 6, 2023 11:17:32 PM SEVERE: +- Weight by SVM[0] (Weight by SVM)
Nov 6, 2023 11:17:32 PM SEVERE: +- Weights to Data (9)[0] (Weights to Data)
Nov 6, 2023 11:17:32 PM SEVERE: +- Set Role (10)[0] (Set Role)
Nov 6, 2023 11:17:32 PM SEVERE: +- Rename (9)[0] (Rename (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Join (8)[0] (Join (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Replace Missing Values (3)[0] (Replace Missing Values)
Nov 6, 2023 11:17:32 PM SEVERE: +- Weight by PCA[0] (Weight by PCA)
Nov 6, 2023 11:17:32 PM SEVERE: +- Weights to Data (10)[0] (Weights to Data)
Nov 6, 2023 11:17:32 PM SEVERE: +- Set Role (11)[0] (Set Role)
Nov 6, 2023 11:17:32 PM SEVERE: +- Rename (10)[0] (Rename (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Join (9)[0] (Join (Deprecated))
Nov 6, 2023 11:17:32 PM SEVERE: +- Write Excel[0] (Write Excel)
Nov 6, 2023 11:17:32 PM SEVERE: java.lang.ArrayIndexOutOfBoundsException: Index 0 out of bounds for length 0
Nov 6, 2023 11:17:38 PM INFO: Operator 'Replace Missing Values' was created with version '5.2.000'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Set Role' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Set Role (3)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Set Role (4)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Set Role (5)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Set Role (6)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Set Role (7)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Set Role (8)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Weight by Relief' was created with version '10.1.003'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Set Role (9)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Join' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Join (2)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Join (3)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Join (4)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Join (5)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Join (6)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Join (7)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Set Role (10)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Join (8)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Weight by PCA' was created with version '9.4.001'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Set Role (11)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:38 PM INFO: Operator 'Join (9)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Replace Missing Values' was created with version '5.2.000'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Set Role' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Set Role (3)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Set Role (4)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Set Role (5)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Set Role (6)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Set Role (7)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Set Role (8)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Weight by Relief' was created with version '10.1.003'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Set Role (9)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Join' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Join (2)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Join (3)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Join (4)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Join (5)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Join (6)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Join (7)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Set Role (10)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Join (8)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Weight by PCA' was created with version '9.4.001'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Set Role (11)' was created with version '5.3.013'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Nov 6, 2023 11:17:40 PM INFO: Operator 'Join (9)' was created with version '5.1.008'. The operator's behaviour has changed as of version '10.3.000' and can be adapted to the latest version in the parameter panel.
Best Answer
can you add a breakpoint before "Weight by Information Gain"?
Maybe your example set is just empty at this point.
Greetings,
Jonas2
Greetings,
Jonas2
