date_str_custom(date_now(),"EEE, MMM d, yyyy h:mm a")
eval(%{macroName})
<...><br><p>Process completed at eval((%{time_stamp<span>})</p><br><...></span>
<?xml version="1.0" encoding="UTF-8"?><process version="9.9.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.9.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_macro" compatibility="9.9.002" expanded="true" height="68" name="Generate Macro" width="90" x="179" y="34">
<parameter key="timestamp" value="date_str_custom(date_now(),"EEE, MMM d, yyyy h:mm:ss a")"/>
</list>
<operator activated="true" class="print_to_console" compatibility="9.9.002" expanded="true" height="68" name="Print to Console" width="90" x="581" y="34">
<parameter key="log_value" value="Process Start: %{timestamp}. Process End: eval(%{timestamp})"/>
<operator activated="true" class="delay" compatibility="9.9.002" expanded="true" height="82" name="Delay" width="90" x="380" y="34">
<parameter key="delay" value="fixed"/>
<parameter key="delay_amount" value="5000"/>
<parameter key="min_delay_amount" value="0"/>
<parameter key="max_delay_amount" value="1000"/>
<connect from_op="Delay" from_port="through 1" to_port="result 1"/>
</process>
