I have a FEM model with different parts/collectors in hypermesh.
is there any tcl/tk available to export each collector as separate file with filename as collector name
thank you
you could build a script to do this, by performing the operations manually once, and then looking at the command.tcl files into your working directory and adding a few layers of TCL scripting on top of it.
What format are you intending to export? Is it mesh? or geometry?
Try something like this
#select and store the component id list for ALL*createmark comps 1 "all"set comps_list [hm_getmark comps 1]*clearmark comps 1#retrieve comps names for the list set compname_list [hm_getvalue comps user_ids=$comps_list dataname=name]#define output direcory >> needs to existset output_dir {c:/temp}#retrieves the template export file from the installationset currenttemplate [hm_info templatefilename]#loop over all components foreach compo $comps_list compnamo $compname_list { #isolate each component *createmark components 2 $compo *createstringarray 2 "elements_on" "geometry_on" *isolateonlyentitybymark 2 1 2 #export .fem file to the output dir, using the compnamo as base name *feoutputmergeincludefiles 0 *setsubmodeltype "HM_INCLUDEFILES" *setentitytypesupportedbyenggid 1 0 *createstringarray 7 "HM_NODEELEMS_SET_COMPRESS_SKIP " "EXPORT_DMIG_LONGFORMAT " "HMSUBSYSTEMCOMMENTS_XML" "HMMATCOMMENTS_XML" "HMBOMCOMMENTS_XML" "INCLUDE_RELATIVE_PATH " "EXPORT_LEGACY_COMP_COMMENTS " *feoutputwithdata "$currenttemplate" [file join $output_dir "${compnamo}.fem"] 0 0 0 1 7}
Hi Adriano
Thank you so much for your Reply. Actually, i am Exporting in nastran/Aabqus Template. based on your initial reply i tried manually using command.cmf and creating a generic one.
Let me go through your logic, thanks a gain
*displaycollectorwithfilter(components,"on","Part_01",1,0)*displaycollectorwithfilter(components,"on","part_02",1,0)*displaycollectorwithfilter(components,"on","Part_03",1,0)*window(0,0,0,0,0)*feoutput("C:/Program Files/Altair/2021.1/hwdesktop/templates/feoutput/nastran/general","E:\Split_files\Assembly_01.dat",1,0,0)*displaycollectorwithfilter(components,"none","",1,0)///--------Export Systems-------//*displaycollectorwithfilter(systcols,"on","B1",1,0)*displaycollectorwithfilter(systcols,"on","B2",1,0)*displaycollectorwithfilter(systcols,"on","B3",1,0)*window(0,0,0,0,0)*feoutput("C:/Program Files/Altair/2021.1/hwdesktop/templates/feoutput/nastran/general","E:\Split_files\co-ordinate.dat",1,0,0)*displaycollectorwithfilter(systcols,"none","",1,0)*endmacro()///--------Export lOADS-------//*displaycollectorwithfilter(loadcols,"on","External-loads",1,0)*window(0,0,0,0,0)*feoutput("C:/Program Files/Altair/2021.1/hwdesktop/templates/feoutput/nastran/general","E:\Split_files\External-loads.dat",1,0,0)*displaycollectorwithfilter(loadcols,"none","",1,0)
