I want to couple motion solve with EDEM to test how my robot moves in sandy terrain. I have followed the tutorials of creating my EDEM simulation (which works on its own) and motionsolve (also works on its own). From there I have followed the following steps:
1. Run EDEM Simulation
2. Save simulation deck from analyst from timestep 0
3. Open simulation deck and start coupling server
4. Go to motionsolve -> assembly -> EDEM
5. Select graphics (in my case my wheels/pedallers, see attached photo)
6. Transfer and Create System
From there, I get the following errors
"14:59:23" "ERROR" "MotionView" "No valid EDEM installation found. [General]"
"14:59:32" "INFO" "MotionView" " 2. Verify that no older EDEM paths have been left in the PATH directory. [General]"
"14:59:32" "INFO" "MotionView" " 3. If (1) + (2) fail, add EDEM path at the highest possible position in the PATH [General]"
"14:59:32" "ERROR" "MotionView" "Failed to export geometries to EDEM [General]"
"14:59:23" "INFO" "MotionView" "Please make sure sure EDEM is installed in the current HW installation directory [General]"
"14:59:32" "ERROR" "MotionView" "Import of EDEM module failed, cannot locate 'EDEMCouplingClient4.dll' or the EDEM version is not compatible with the HW version [General]"
"14:59:32" "INFO" "MotionView" "To resolve the missing EDEM module problem, please: [General]"
"14:59:32" "INFO" "MotionView" " 1. Make sure EDEM/hwsolvers are installed in the current HW installation directory [General]"
I then uninstalled my 2022.3 EDEM and reinstalled 2023 EDEM to match my Hyperworks version 2023. So my current program folder structure is as follows:
C:\Program Files\Altair\2023\EDEM\bin
C:\Program Files\Altair\2023\hwsolvers\motionsolve\bin
I have added the following lines to the top of my path in environment variables and restarted my machine:
C:\Program Files\Altair\2023\hwsolvers\motionsolve\lib
However still the same error.
Any advice would be much appreciated
Kind regards,
Gaetan
