Hi together, I have some issues with my project. My task is to generate target variable training data (Retouren_Training.txt),
which determines the class membership according to the case description for the return rate.
In concrete terms, all customers whose forecast return quota(= RETOUREN_MENGE/LIEFER_MENGE) is a maximum of 0.18 (ie a
maximum of 18%) are considered to be low returners. On the other hand, all customers whose predicted return rate is greater
than 0.4 (ie greater than 40%) are considered high returners. All other customers are neutral, ie neither low nor high returners.
Furthermore, a data mining model is to be created, which is to be applied to the 9,900 customers to be classified as an example (Retouren_Klassigung.txt) and a class assignment in neutral, low or high returns.
I created the model, calculated the variable, but the Apply model still doesn't work. Where is the error? Would be very grateful for your support.
Best wishes Lina
