<?xml version="1.0" encoding="UTF-8"?><process version="9.10.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.10.013" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="-1"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.10.013" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="34"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="text This is an apple."/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="split" compatibility="9.10.013" expanded="true" height="82" name="Split" width="90" x="246" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="split_pattern" value=" "/> <parameter key="split_mode" value="ordered_split"/> </operator> <operator activated="true" class="set_macro" compatibility="9.10.013" expanded="true" height="82" name="Set Macro" width="90" x="380" y="34"> <parameter key="macro" value="counter"/> <parameter key="value" value="0"/> </operator> <operator activated="true" class="concurrency:loop_attributes" compatibility="9.10.013" expanded="true" height="103" name="Loop Attributes" width="90" x="514" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="attribute_name_macro" value="attr"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="false"/> <process expanded="true"> <operator activated="true" class="extract_macro" compatibility="9.10.013" expanded="true" height="68" name="Extract Macro" width="90" x="45" y="34"> <parameter key="macro" value="word"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="%{attr}"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="generate_macro" compatibility="9.10.013" expanded="true" height="82" name="Calculate end" width="90" x="179" y="34"> <list key="function_descriptions"> <parameter key="end" value="eval(%{counter}) + length(%{word}) - 1"/> </list> </operator> <operator activated="true" class="utility:create_exampleset" compatibility="9.10.013" expanded="true" height="68" name="Create ExampleSet (2)" width="90" x="313" y="136"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="Word,Start,End %{word},%{counter},%{end}"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="generate_macro" compatibility="9.10.013" expanded="true" height="82" name="Count to the next word" width="90" x="514" y="136"> <list key="function_descriptions"> <parameter key="counter" value="eval(%{end}) + 2"/> </list> </operator> <connect from_port="input 1" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Calculate end" to_port="through 1"/> <connect from_op="Calculate end" from_port="through 1" to_port="output 1"/> <connect from_op="Create ExampleSet (2)" from_port="output" to_op="Count to the next word" to_port="through 1"/> <connect from_op="Count to the next word" from_port="through 1" to_port="output 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> <portSpacing port="sink_output 3" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="9.10.013" expanded="true" height="82" name="Append" width="90" x="648" y="85"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> <parameter key="merge_type" value="all"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Loop Attributes" to_port="input 1"/> <connect from_op="Loop Attributes" from_port="output 2" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
This will give you the start and end indices for each word.
