<context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.1.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="10.1.001" expanded="true" height="68" name="Retrieve diamonds1" width="90" x="112" y="340"> <parameter key="repository_entry" value="diamonds1"/> </operator> <operator activated="true" class="concurrency:optimize_parameters_grid" compatibility="10.1.001" expanded="true" height="124" name="Optimize Parameters (Grid)" width="90" x="447" y="340"> <list key="parameters"> <parameter key="Filter Example Range.last_example" value="[5000;40000;7;linear]"/> </list> <parameter key="error_handling" value="fail on error"/> <parameter key="log_performance" value="true"/> <parameter key="log_all_criteria" value="false"/> <parameter key="synchronize" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="filter_example_range" compatibility="10.1.001" expanded="true" height="82" name="Filter Example Range" width="90" x="179" y="85"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="200"/> <parameter key="invert_filter" value="false"/> </operator> <operator activated="true" class="h2o:generalized_linear_model" compatibility="10.0.000" expanded="true" height="124" name="Generalized Linear Model" width="90" x="380" y="85"> <parameter key="family" value="AUTO"/> <parameter key="link" value="family_default"/> <parameter key="solver" value="AUTO"/> <parameter key="reproducible" value="false"/> <parameter key="maximum_number_of_threads" value="4"/> <parameter key="use_regularization" value="false"/> <parameter key="lambda_search" value="false"/> <parameter key="number_of_lambdas" value="0"/> <parameter key="lambda_min_ratio" value="0.0"/> <parameter key="early_stopping" value="true"/> <parameter key="stopping_rounds" value="3"/> <parameter key="stopping_tolerance" value="0.001"/> <parameter key="standardize" value="true"/> <parameter key="non-negative_coefficients" value="false"/> <parameter key="add_intercept" value="true"/> <parameter key="compute_p-values" value="false"/> <parameter key="remove_collinear_columns" value="false"/> <parameter key="missing_values_handling" value="MeanImputation"/> <parameter key="max_iterations" value="0"/> <parameter key="specify_beta_constraints" value="false"/> <list key="beta_constraints"/> <parameter key="max_runtime_seconds" value="0"/> <list key="expert_parameters"/> </operator> <operator activated="true" class="apply_model" compatibility="10.1.001" expanded="true" height="82" name="Apply Model" width="90" x="581" y="85"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_regression" compatibility="10.1.001" expanded="true" height="82" name="Performance" width="90" x="782" y="34"> <parameter key="main_criterion" value="first"/> <parameter key="root_mean_squared_error" value="true"/> <parameter key="absolute_error" value="false"/> <parameter key="relative_error" value="false"/> <parameter key="relative_error_lenient" value="false"/> <parameter key="relative_error_strict" value="false"/> <parameter key="normalized_absolute_error" value="false"/> <parameter key="root_relative_squared_error" value="false"/> <parameter key="squared_error" value="false"/> <parameter key="correlation" value="false"/> <parameter key="squared_correlation" value="false"/> <parameter key="prediction_average" value="false"/> <parameter key="spearman_rho" value="false"/> <parameter key="kendall_tau" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <operator activated="true" class="retrieve" compatibility="10.1.001" expanded="true" height="68" name="Retrieve diamonds2" width="90" x="313" y="391"> <parameter key="repository_entry" value="diamonds2"/> </operator> <operator activated="true" class="apply_model" compatibility="10.1.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="581" y="238"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_regression" compatibility="10.1.001" expanded="true" height="82" name="Performance (2)" width="90" x="782" y="187"> <parameter key="main_criterion" value="first"/> <parameter key="root_mean_squared_error" value="true"/> <parameter key="absolute_error" value="false"/> <parameter key="relative_error" value="false"/> <parameter key="relative_error_lenient" value="false"/> <parameter key="relative_error_strict" value="false"/> <parameter key="normalized_absolute_error" value="false"/> <parameter key="root_relative_squared_error" value="false"/> <parameter key="squared_error" value="false"/> <parameter key="correlation" value="false"/> <parameter key="squared_correlation" value="false"/> <parameter key="prediction_average" value="false"/> <parameter key="spearman_rho" value="false"/> <parameter key="kendall_tau" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <operator activated="true" class="log" compatibility="10.1.001" expanded="true" height="103" name="Log" width="90" x="1050" y="85"> <list key="log"> <parameter key="Training RMSE" value="operator.Performance.value.root_mean_squared_error"/> <parameter key="Test RMSE" value="operator.Performance (2).value.root_mean_squared_error"/> <parameter key="Iteration Number" value="operator.Optimize Parameters (Grid).value.iteration_number"/> </list> <parameter key="sorting_type" value="none"/> <parameter key="sorting_k" value="100"/> <parameter key="persistent" value="false"/> </operator> <connect from_port="input 1" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Generalized Linear Model" to_port="training set"/> <connect from_op="Generalized Linear Model" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Generalized Linear Model" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Apply Model" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Performance" from_port="performance" to_op="Log" to_port="through 1"/> <connect from_op="Retrieve diamonds2" from_port="output" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_op="Log" to_port="through 2"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Retrieve diamonds1" from_port="output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8"?><process version="10.1.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.1.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="10.1.001" expanded="true" height="68" name="Retrieve diamonds" width="90" x="112" y="391"> <parameter key="repository_entry" value="diamonds"/> </operator> <operator activated="true" class="split_data" compatibility="10.1.001" expanded="true" height="103" name="Split Data" width="90" x="380" y="391"> <enumeration key="partitions"> <parameter key="ratio" value="0.8"/> <parameter key="ratio" value="0.2"/> </enumeration> <parameter key="sampling_type" value="automatic"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <operator activated="true" class="remember" compatibility="10.1.001" expanded="true" height="68" name="Remember" width="90" x="581" y="595"> <parameter key="name" value="TestSet"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="store_which" value="1"/> <parameter key="remove_from_process" value="true"/> </operator> <operator activated="true" class="concurrency:optimize_parameters_grid" compatibility="10.1.001" expanded="true" height="124" name="Optimize Parameters (Grid)" width="90" x="715" y="85"> <list key="parameters"> <parameter key="Filter Example Range.last_example" value="[5000;40000;7;linear]"/> </list> <parameter key="error_handling" value="fail on error"/> <parameter key="log_performance" value="true"/> <parameter key="log_all_criteria" value="true"/> <parameter key="synchronize" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="filter_example_range" compatibility="10.1.001" expanded="true" height="82" name="Filter Example Range" width="90" x="112" y="85"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="5000"/> <parameter key="invert_filter" value="false"/> </operator> <operator activated="true" class="extract_macro" compatibility="10.1.001" expanded="true" height="68" name="Extract Macro" width="90" x="246" y="85"> <parameter key="macro" value="SampleSize"/> <parameter key="macro_type" value="number_of_examples"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value=""/> <list key="additional_macros"/> </operator> <operator activated="true" class="h2o:generalized_linear_model" compatibility="10.0.000" expanded="true" height="124" name="Generalized Linear Model" width="90" x="380" y="85"> <parameter key="family" value="gaussian"/> <parameter key="link" value="identity"/> <parameter key="solver" value="AUTO"/> <parameter key="reproducible" value="false"/> <parameter key="maximum_number_of_threads" value="4"/> <parameter key="use_regularization" value="false"/> <parameter key="lambda_search" value="false"/> <parameter key="number_of_lambdas" value="0"/> <parameter key="lambda_min_ratio" value="0.0"/> <parameter key="early_stopping" value="true"/> <parameter key="stopping_rounds" value="3"/> <parameter key="stopping_tolerance" value="0.001"/> <parameter key="standardize" value="true"/> <parameter key="non-negative_coefficients" value="false"/> <parameter key="add_intercept" value="true"/> <parameter key="compute_p-values" value="false"/> <parameter key="remove_collinear_columns" value="false"/> <parameter key="missing_values_handling" value="MeanImputation"/> <parameter key="max_iterations" value="0"/> <parameter key="specify_beta_constraints" value="false"/> <list key="beta_constraints"/> <parameter key="max_runtime_seconds" value="0"/> <list key="expert_parameters"/> </operator> <operator activated="true" class="apply_model" compatibility="10.1.001" expanded="true" height="82" name="Apply Model" width="90" x="581" y="85"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_regression" compatibility="10.1.001" expanded="true" height="82" name="Performance" width="90" x="782" y="34"> <parameter key="main_criterion" value="first"/> <parameter key="root_mean_squared_error" value="true"/> <parameter key="absolute_error" value="false"/> <parameter key="relative_error" value="false"/> <parameter key="relative_error_lenient" value="false"/> <parameter key="relative_error_strict" value="false"/> <parameter key="normalized_absolute_error" value="false"/> <parameter key="root_relative_squared_error" value="false"/> <parameter key="squared_error" value="false"/> <parameter key="correlation" value="false"/> <parameter key="squared_correlation" value="false"/> <parameter key="prediction_average" value="false"/> <parameter key="spearman_rho" value="false"/> <parameter key="kendall_tau" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <operator activated="true" class="recall" compatibility="10.1.001" expanded="true" height="68" name="Recall" width="90" x="246" y="340"> <parameter key="name" value="TestSet"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="remove_from_store" value="false"/> </operator> <operator activated="true" class="apply_model" compatibility="10.1.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="581" y="238"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_regression" compatibility="10.1.001" expanded="true" height="82" name="Performance (2)" width="90" x="782" y="187"> <parameter key="main_criterion" value="first"/> <parameter key="root_mean_squared_error" value="true"/> <parameter key="absolute_error" value="false"/> <parameter key="relative_error" value="false"/> <parameter key="relative_error_lenient" value="false"/> <parameter key="relative_error_strict" value="false"/> <parameter key="normalized_absolute_error" value="false"/> <parameter key="root_relative_squared_error" value="false"/> <parameter key="squared_error" value="false"/> <parameter key="correlation" value="false"/> <parameter key="squared_correlation" value="false"/> <parameter key="prediction_average" value="false"/> <parameter key="spearman_rho" value="false"/> <parameter key="kendall_tau" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <operator activated="true" class="log" compatibility="10.1.001" expanded="true" height="103" name="Log" width="90" x="1050" y="85"> <list key="log"> <parameter key="Training RMSE" value="operator.Performance.value.root_mean_squared_error"/> <parameter key="Test RMSE" value="operator.Performance (2).value.root_mean_squared_error"/> <parameter key="Iteration" value="operator.Optimize Parameters (Grid).value.iteration_number"/> <parameter key="Sample Size" value="operator.Extract Macro.value.macro_value"/> </list> <parameter key="sorting_type" value="none"/> <parameter key="sorting_k" value="100"/> <parameter key="persistent" value="false"/> </operator> <connect from_port="input 1" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Generalized Linear Model" to_port="training set"/> <connect from_op="Generalized Linear Model" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Generalized Linear Model" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Apply Model" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Performance" from_port="performance" to_op="Log" to_port="through 1"/> <connect from_op="Recall" from_port="result" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_op="Log" to_port="through 2"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Retrieve diamonds" from_port="output" to_op="Split Data" to_port="example set"/> <connect from_op="Split Data" from_port="partition 1" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Split Data" from_port="partition 2" to_op="Remember" to_port="store"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
