How to save a prediction model generated by automodel for future analysis
luiz_gabriel
luiz_gabriel New Altair Community Member
Hello!
How can I save a prediction model generated by automodel, to use it in other databases later?
I don't want to save the process, just the generated A.I. model, so that in the future I can only predict new data based on this previously saved model.
Was I clear?
Thanks!!
  • MartinLiebig
    MartinLiebig
    there is a save button on the lower right, which exports everything to the repo. You can then use the Score Set process to score new data.
    Cheers,
    Martin
  • luiz_gabriel
    edited June 2023
    @MartinLiebig Hi Martin! Thanks for the answer.
    Could you explain it to me visually through printscreen, as I met rapidminer a few days ago?
    Which point should i connect to the widget, since the automodel generates a huge process with many connections?
    And how would this process of using the previously generated learning with new data be done?
    Thank you very much!
