Exporting the preprocessed text data into Excel File
I really need your help. I have created a predictive model. The dataset I'm using contains several text attributes that were merged into one text attribute/column during the preprocessing phase. This preprocessing involved steps such as tokenization, stopword removal, token filtering, stemming, and generating n-grams. Could you please guide me on how to unmerged back all those text attributes and into different columns as they were before? Additionally, I would like to export the data into an Excel file so that I can compare the original unprocessed text with the preprocessed text. Thank you for your assistance.
1 - 2 of
21
Since there's no .rmp or data files included in your post, I am merely assuming that you could use the SELECT ATTRIBUTES operator to unmerge attributes. Exporting Excel has the WRITE EXCEL operator. hth.
