Error :
Process failed: Database error occurred: The incoming tabular data stream (TDS) remote procedure call (RPC) protocol stream is incorrect. Parameter 1 (""): The supplied value is not a valid instance of data type float. Check the source data for invalid values. An example of an invalid value is data of numeric type with scale greater than precision.
