<?xml version="1.0" encoding="UTF-8"?><process version="10.1.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.1.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="10.1.002" expanded="true" height="68" name="Read CSV" width="90" x="45" y="34"> <parameter key="csv_file" value="https://us.v-cdn.net/6038102/uploads/editor/p5/vgkjyxg5z8uk.csv"/> <parameter key="column_separators" value=";"/> <parameter key="trim_lines" value="false"/> <parameter key="use_quotes" value="true"/> <parameter key="quotes_character" value="""/> <parameter key="escape_character" value="\"/> <parameter key="skip_comments" value="false"/> <parameter key="comment_characters" value="#"/> <parameter key="starting_row" value="1"/> <parameter key="parse_numbers" value="true"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="date_format" value=""/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="encoding" value="UTF-8"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"/> <parameter key="read_not_matching_values_as_missings" value="true"/> </operator> <operator activated="true" class="filter_example_range" compatibility="10.1.002" expanded="true" height="82" name="Filter Example Range" width="90" x="179" y="34"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="1"/> <parameter key="invert_filter" value="false"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="10.1.002" expanded="true" height="82" name="Rename by Replacing" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="att"/> </operator> <operator activated="true" class="concurrency:loop_attributes" compatibility="10.1.002" expanded="true" height="103" name="Loop Attributes" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="attribute_name_macro" value="loop"/> <parameter key="reuse_results" value="true"/> <parameter key="enable_parallel_execution" value="false"/> <process expanded="true"> <operator activated="true" class="multiply" compatibility="10.1.002" expanded="true" height="103" name="Multiply" width="90" x="45" y="34"/> <operator activated="true" class="blending:select_attributes" compatibility="10.1.002" expanded="true" height="82" name="Select Attributes" width="90" x="112" y="340"> <parameter key="type" value="include attributes"/> <parameter key="attribute_filter_type" value="one attribute"/> <parameter key="select_attribute" value="%{loop}"/> <parameter key="select_subset" value=""/> <parameter key="also_apply_to_special_attributes_(id,_label..)" value="false"/> </operator> <operator activated="true" class="generate_macro" compatibility="10.1.002" expanded="true" height="82" name="Generate Macro" width="90" x="246" y="340"> <list key="function_descriptions"> <parameter key="attribute" value="concat("tripplet_", str(floor((round(parse(%{loop}))-1)/3)))"/> </list> </operator> <operator activated="true" class="generate_empty_attribute" compatibility="10.1.002" expanded="true" height="82" name="Generate Empty Attribute" width="90" x="380" y="340"> <parameter key="name" value="%{attribute}"/> <parameter key="value_type" value="integer"/> </operator> <operator activated="true" class="operator_toolbox:merge" compatibility="2.14.000" expanded="true" height="103" name="Merge Attributes (2)" width="90" x="514" y="85"> <parameter key="handling_of_duplicate_attributes" value="keep_only_first"/> <parameter key="handling_of_special_attributes" value="keep_only_first"/> <parameter key="handling_of_duplicate_annotations" value="keep_only_first"/> </operator> <operator activated="true" class="blending:generate_columns" compatibility="10.1.002" expanded="true" height="82" name="Generate Attributes" width="90" x="715" y="85"> <list key="function_descriptions"> <parameter key="%{attribute}" value="if(missing(cell_value(%{attribute}, 1, NOMINAL)), cell_value(%{loop}, 1, NOMINAL), concat(cell_value(%{attribute} , 1, NOMINAL), " ", cell_value(%{loop},1, NOMINAL)))"/> </list> <parameter key="keep_all_columns" value="true"/> </operator> <operator activated="true" class="blending:select_attributes" compatibility="10.1.002" expanded="true" height="82" name="Select Attributes (2)" width="90" x="849" y="85"> <parameter key="type" value="exclude attributes"/> <parameter key="attribute_filter_type" value="one attribute"/> <parameter key="select_attribute" value="%{loop}"/> <parameter key="select_subset" value=""/> <parameter key="also_apply_to_special_attributes_(id,_label..)" value="false"/> </operator> <connect from_port="input 1" to_op="Multiply" to_port="input"/> <connect from_port="input 2" to_op="Merge Attributes (2)" to_port="example set 1"/> <connect from_op="Multiply" from_port="output 1" to_port="output 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Generate Empty Attribute" to_port="example set input"/> <connect from_op="Generate Empty Attribute" from_port="example set output" to_op="Merge Attributes (2)" to_port="example set 2"/> <connect from_op="Merge Attributes (2)" from_port="merged set" to_op="Generate Attributes" to_port="table input"/> <connect from_op="Generate Attributes" from_port="table output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_port="output 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="source_input 3" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> <portSpacing port="sink_output 3" spacing="0"/> </process> </operator> <operator activated="true" class="transpose" compatibility="10.1.002" expanded="true" height="82" name="Transpose" width="90" x="581" y="34"/> <operator activated="true" class="split" compatibility="10.1.002" expanded="true" height="82" name="Split" width="90" x="715" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="split_pattern" value="\s"/> <parameter key="split_mode" value="ordered_split"/> </operator> <operator activated="true" class="guess_types" compatibility="10.1.002" expanded="true" height="82" name="Guess Types" width="90" x="849" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="decimal_point_character" value="."/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Loop Attributes" to_port="input 1"/> <connect from_op="Loop Attributes" from_port="output 2" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Guess Types" to_port="example set input"/> <connect from_op="Guess Types" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
