Old processes don't break, since the old set role operator is still there and does what it did before.
The whole thing of being able to use custom roles as one of the features basically no beginner found by himself. With the changes in the role system we allow users to find it easier. Also it was always confusing why roles needed to be unique. This is now also changed.
But yeah, Multi-Label and Multi-Horizon forecast operators may have challenges now.
Dirty work around is by the way to just copy the old set role from an old process and use it in the new one.
Metadata \+ (\d+).<br><p></p>
which is what I think the role types get set to but I did the filtering another way so it doesn't matter for me now.
It would be nice if Set Role would allow the advanced usage like it used to since old processes using it will break otherwise. Here's one I prepared earlier (in 2011 - so somewhat old).
https://rapidminernotes.blogspot.com/2011/07/ignoring-many-attributes.html
and it would also be nice if Set Role could allow horizon as an attribute type since there's every chance an example set will contain metadata already and this will mess up the numbering.
cheers
Andrew
