🎉Community Raffle - Win $25
Join and Win
Aggregate (like count) on non-sql data (like created example set)
User: "Ziggizag"
New Altair Community Member
Updated by Jocelyn
Is there a way to aggregate without SQL?
Let's say I have a huge MySQL data set, and I map some values to arbitrary "categories" through a join with a "created example set". For example, I assign a value "high", to records where "offer_id" was 1,3,5 or 7, and I assign a value "low" to records where "offer_id" was 2, 4 or 6. Presume I do not want to load the mapping "offer_id" --> "category" into a database at the moment, but I like having it in a handy "created example set".
I have noticed, rather unfortunately, that "category" argument (which is set on "example data set" by the "set meta data" operator) is not visible to "aggregate" operator, so I see no easy way to count "high" and "low" records after join.
The question is: how to aggregate by attributes coming from such an "example data set"?
Here you are my process:
1 - 1 of 11
    User: "YYH"
    There are at least two methods. You can join the mapping table to the big table. Or replace the offer id with dictionary. Then use aggregate operator.
    I replace the id in golf data, here is the sample process that you can import into your own RM studio.
