Can I convert a table in a text file to Excel using RM?
User: "kimjk3559"
Altair Community Member
Updated by Jocelyn
For example,
   name              age               job
   aaaa               bbbb             ccc
   des1               des2             des3
      1                    2                3
   dddd               eeee             fff
   des1               des2             des3
      4                    5                6
There is a text file with many tables of this type, and these to..
   name              age               job            des1               des2             des3
   aaaa               bbbb             ccc              1                    2                3
   dddd               eeee             fff               4                    5                6
I want to convert it to an Excel file of this type.
I tried filter with regular expression but I can't get the idea out.
Any help or even a little hint is appreciated.
Tks
1 - 1 of 11
    User: "BalazsBaranyRM"
    New Altair Community Member
    Accepted Answer
    Hi!
    Your tables are formatted for viewing, not processing. But you can still import them.
    I would try Read CSV with a weird separator character that is not in the tables, like § or *. This gives you the entire rows in one column.
    Then apply Trim to remove spaces in the beginning and the end of the rows. Then Split with a regular expression like "[\t ]+", this will split up the column on the variable number of spaces (or tabulators if they are in the data) . If the Name or some other attribute have (single) spaces in the contents, try a regular expression with a quantifier:  {2,}|\t
    Then you can rename the columns as you need.
    When you're done, you can use Write Excel to export the results.
    Balázs
