Following the WPS installation guide for linux x86, I'm trying to run the command that apply the license key.
I can't find how to fet it in the machine ?
Here's the documentation to apply :
Apply a licence key
You require a license key to run WPS Analytics. The licence key is
downloaded from the World Programming website and applied from the
command line. To apply a licence key use the following command:
<wps-4.4.3-GA-release-installation-dir>/bin/wps -stdio
-setinit < <wps-key-file>
A message will confirm the license had been applied successfully.
Can you help find this wps-key-file ?
Olivier
