Altair RISE
Nominate Yourself Now!
My rapidminer can't visualization, it only shows code. What's the problem ?
Cstay
Caperez
Hi
@Cstay
You can try two things that work for me:
1- Activate the safe mode of HTML5 in Settings -> Preferences -> User Interface -> HTML5 Safe mode and restart RM
2- Reinstallation of RM
Best,
Cesar
Marco_Boeck
Can you please post the contents of the rapidminer-studio.log? You can find it in USER/.RapidMiner.
Marco
Cstay
Mar 01, 2023 12:12:15 AM com.rapidminer.tools.I18N setLocale
INFO: Setting locale.
INFO: Using locale en.
Mar 01, 2023 12:12:15 AM com.rapidminer.gui.RapidMinerGUI run
INFO: Launching RapidMiner 10.1.001, platform WIN64, with Java Eclipse Adoptium 11.0.16 on Windows 11 (10.0 / amd64)
Mar 01, 2023 12:12:16 AM com.rapidminer.tools.PlatformUtilities logInfo
INFO: rapidminer.home is 'C:\Program Files\RapidMiner\RapidMiner Studio'.
Mar 01, 2023 12:12:19 AM com.rapidminer.core.license.ProductConstraintManager initialize
INFO: Initializing license manager.
INFO: Using default license location.
INFO: Registering default product.
Mar 01, 2023 12:12:20 AM com.rapidminer.repository.FileRepositoryProvider load
WARNING: Unknown tag: filesystemRepository
Mar 01, 2023 12:12:20 AM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
INFO: Global Search category repository registered.
Mar 01, 2023 12:12:20 AM com.rapidminer.tools.plugin.Plugin registerPlugins
INFO: Register plugin: Cloud Connectivity
INFO: Register plugin: Data Editor
INFO: Register plugin: H2O
INFO: Register plugin: Model Simulator
INFO: Register plugin: Operator Recommender
INFO: Register plugin: Process Scheduling
INFO: Register plugin: Advanced File Connectors
INFO: Register plugin: Blending
INFO: Register plugin: Browser
INFO: Register plugin: Concurrency
INFO: Register plugin: CTA
INFO: Register plugin: HTML5 Charts
INFO: Register plugin: JDBC Connectors
INFO: Register plugin: Legacy Result Access
INFO: Register plugin: Productivity
INFO: Register plugin: Professional
INFO: Register plugin: Remote Repository
INFO: Register plugin: Utility
INFO: Register plugin: Social Media
INFO: Register plugin: Time Series
Mar 01, 2023 12:12:20 AM com.rapidminer.tools.ClassColorMap parseKey
SEVERE: Unknown IO class: com.rapidminer.operator.visualization.DataStatistics
Mar 01, 2023 12:12:28 AM com.rapidminer.tools.config.ConfigurationManager register
WARNING: Registered configurator Twitter Connection. Please update your extension to use the new connection framework!
Mar 01, 2023 12:12:32 AM com.rapidminer.extension.browser.PluginInitBrowser lambda$initPlugin$2
INFO: Async: Init browser setup.
Mar 01, 2023 12:12:33 AM com.rapidminer.tools.config.ConfigurationManager register
WARNING: Registered configurator Amazon S3 Connection. Please update your extension to use the new connection framework!
WARNING: Registered configurator Azure Blob Storage Connection. Please update your extension to use the new connection framework!
WARNING: Registered configurator Azure Data Lake Storage Gen1 Connection. Please update your extension to use the new connection framework!
WARNING: Registered configurator gui.configurable.cloud.azure.gen2.name. Please update your extension to use the new connection framework!
WARNING: Registered configurator Google Cloud Storage Connection. Please update your extension to use the new connection framework!
WARNING: Registered configurator Dropbox Connection. Please update your extension to use the new connection framework!
Mar 01, 2023 12:12:34 AM com.rapidminer.extension.browser.PluginInitBrowser lambda$initPlugin$2
INFO: Async: Basic browser setup test starting.
Mar 01, 2023 12:12:35 AM com.rapidminer.extension.browser.PluginInitBrowser lambda$initPlugin$2
INFO: Async: Created basic browser instance.
INFO: Async: Loaded basic browser test content. Executing functionality check.
INFO: Async: Basic browser setup test successful.
Mar 01, 2023 12:12:40 AM com.rapidminer.extension.jdbc.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver org.mariadb.jdbc.Driver not found. Probably the driver is not installed.
INFO: JDBC driver org.postgresql.Driver not found. Probably the driver is not installed.
INFO: JDBC driver net.sourceforge.jtds.jdbc.Driver not found. Probably the driver is not installed.
INFO: JDBC driver org.hsqldb.jdbcDriver not found. Probably the driver is not installed.
Mar 01, 2023 12:12:40 AM com.rapidminer.extension.jdbc.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
WARNING: Missing database driver class name for Ingres
INFO: JDBC driver net.ucanaccess.jdbc.UcanaccessDriver not found. Probably the driver is not installed.
INFO: JDBC driver net.snowflake.client.jdbc.SnowflakeDriver not found. Probably the driver is not installed.
INFO: JDBC driver oracle.jdbc.OracleDriver not found. Probably the driver is not installed.
INFO: JDBC driver com.microsoft.sqlserver.jdbc.SQLServerDriver not found. Probably the driver is not installed.
Mar 01, 2023 12:12:54 AM com.rapidminer.repository.RepositoryManager registerExtensionSamples
INFO: Registered 'Time Series' as sample folder.
Mar 01, 2023 12:12:56 AM com.rapidminer.tools.plugin.Plugin initAll
INFO: Extension Utility 10.1.1 was loaded in 912ms.
INFO: Extension Professional 10.1.1 was loaded in 915ms.
INFO: Extension Operator Recommender 10.0.0 was loaded in 920ms.
INFO: Extension Productivity 10.1.1 was loaded in 947ms.
INFO: Extension Social Media 10.0.0 was loaded in 991ms.
INFO: Extension Legacy Result Access 10.1.1 was loaded in 994ms.
INFO: Extension Data Editor 10.0.0 was loaded in 1030ms.
INFO: Extension Process Scheduling 10.0.0 was loaded in 1071ms.
INFO: Extension Time Series 10.1.0 was loaded in 1088ms.
INFO: Extension HTML5 Charts 10.1.1 was loaded in 1118ms.
INFO: Extension Advanced File Connectors 10.1.1 was loaded in 1177ms.
INFO: Extension Blending 10.1.1 was loaded in 1345ms.
INFO: Extension CTA 10.1.1 was loaded in 1417ms.
INFO: Extension Model Simulator 10.0.0 was loaded in 1454ms.
INFO: Extension Remote Repository 10.1.1 was loaded in 1622ms.
INFO: Extension H2O 10.0.0 was loaded in 1766ms.
INFO: Extension Browser 10.1.1 was loaded in 1772ms.
INFO: Extension Concurrency 10.1.1 was loaded in 1890ms.
INFO: Extension Cloud Connectivity 10.1.0 was loaded in 2643ms.
WARNING: Extension JDBC Connectors 10.1.1 was loaded in 10 s.
Mar 01, 2023 12:12:57 AM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
INFO: Global Search category operator registered.
Mar 01, 2023 12:14:03 AM com.rapidminer.tools.config.ClientConfigurationManager loadAllParameters
INFO: No configuration file found for Amazon S3 Connection
INFO: No configuration file found for Azure Blob Storage Connection
INFO: No configuration file found for Azure Data Lake Storage Gen1 Connection
INFO: No configuration file found for gui.configurable.cloud.azure.gen2.name
INFO: No configuration file found for Dropbox Connection
INFO: No configuration file found for Google Cloud Storage Connection
Mar 01, 2023 12:14:04 AM com.rapidminer.tools.config.ClientConfigurationManager loadAllParameters
INFO: No configuration file found for Twitter Connection
Mar 01, 2023 12:14:08 AM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
INFO: Global Search category actions registered.
Mar 01, 2023 12:14:08 AM com.rapidminer.extension.browser.PluginInitBrowser lambda$initGui$5
INFO: Async: Hardware accelerated browser setup test starting.
INFO: Async: Created hardware accelerated browser instance.
INFO: Async: Loaded hardware accelerated browser test content. Executing functionality check.
INFO: Async: Hardware accelerated browser setup test successful.
Mar 01, 2023 12:14:12 AM com.rapidminer.extension.remote.PluginInitRemoteRepository$2 run
INFO: Community repository 'Community Samples' added.
INFO: Community repository 'Training Resources' added.
Mar 01, 2023 12:14:12 AM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
INFO: Global Search category academy registered.
Mar 01, 2023 12:14:12 AM com.rapidminer.gui.search.GlobalSearchGUIRegistry registerSearchVisualizationProvider
INFO: Global Search GUI provider added for category academy.
Mar 01, 2023 12:14:12 AM com.rapidminer.gui.MainFrame finishInitialization
WARNING: Not adding legacy connections menu even though legacy configurables are present. Check log for offending extensions
Mar 01, 2023 12:14:13 AM com.rapidminer.gui.search.GlobalSearchGUIRegistry registerSearchVisualizationProvider
INFO: Global Search GUI provider added for category operator.
INFO: Global Search GUI provider added for category repository.
INFO: Global Search GUI provider added for category actions.
Mar 01, 2023 12:14:13 AM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
INFO: Global Search category marketplace registered.
INFO: Global Search GUI provider added for category marketplace.
Mar 01, 2023 12:14:14 AM com.rapidminer.deployment.update.client.MarketplaceUpdateManager$1 run
INFO: Checking for updates.
Mar 01, 2023 12:14:18 AM com.rapidminer.deployment.update.client.MarketplaceUpdateManager$1 run
INFO: No updates since 2/27/23 2:46 PM.
