I have done three point bend test using hypercrash to make model. I am using radioss solver. I am able to create model without any error. But there is no option to study result is coming in radioss solver window. Kindly help.
results can be investigated in Hyperview, not in Radioss solver window.
But how to plot it in hyperview? Which file can I use to plot result? In radioss solver I got following attached message
In the run folder open:
But I have not got these files in output folder.
Files I have got I am attaching follow.
You need to define simulation controls. Use Tools>engine file assistant to set up the simulation controls. Define animation output frequency ANIM/DT to get the animation output.
