How to use one attribute to subtract against another attribute
chee_altair_com
In a dataset, the attribute names are:
State 2020 2019 2018 2017 2016
What is required is the difference between the numeric columns, say:
column diff2020 = column 2020 - column 2019.
I've tried using loop_attribute operator. Inside this loop process, I have a Generate Attribute operator.
For this Generate Attribute operator:
the attribute_name is: diff_%{loop_attribute}
the function expression is: eval(%{loop_attribute}) - eval(%{loop_attribute}-1)
the above is an incorrect function expression. What should the correct function expression be?
Thanks
Chee
chee_altair_com
Found the answer.
In the Generate Attribute, the function expression syntax is: (#{loop_var} - #{prevloop_var})/ #{prevloop_var}
This is the column based operations to calculate relative difference between two consecutive years.
The attribute(column) names are loop_var created using Set Macro and the calculated name prevloop_var using Generate Macro.
chee_altair_com
following above, I've discovered the syntax for column is the square brackets.
So it would be something like [2020] - [2019] if we write manually.
But programmatically for many columns, it should be:
[%{loop_attribute} ] - [ %{loop_attribute} -1 ]
Obviously, the syntax above is wrong. But can anyone tell me what should the syntax be, that can be entered into the Generate Attributes field.
Thanks
Chee
chee_altair_com
Found the answer.
