Hello I'm Shin.
I want to export the topology optimization result to step file by using ossmooth.
In target model, it contains solid element and shell element.
design area is only soild one, whole shell part is nondesign area.
I confirmed reasonable result in Hyperview ISO view. It contains solid part (topology optimized result) and original shell part.
I want to export the topology optimization result which exactly reflect the iso view result,
but when doing ossmooth only solid part can be confirmed.
How can i resolve this problem?
