How to display both the label and value in the exported map
User: "Zabih"
New Altair Community Member
Updated by Jocelyn
Hi guys, need help urgently.
I am trying to show both the province label as wells as the value on the map before exporting it in jpeg format. However, I can only see the values in the interactive mode (as an example, Hirat province where I can only see the numerical values in the interactive mode alone). Can you guys please help?
1 - 1 of 11
    User: "Caperez"
    Accepted Answer
    Hi @Zabih
    Tooltip is a dynamic element and is not possible to display all them at the same time ( as far I know)
    other option is to use a trick to display more information with labels.
    What you can do is to introduce a little piece of code into Plot style->Labels style->.
    Rapidminer is based in Highcharts so using the point class is possible to add more information into the graphs.
    in this case I used {point.x}:{point.name}
    Best
    Cesar
