<?xml version="1.0" encoding="UTF-8"?><process version="9.10.010"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.10.010" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="-1"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" class="text:process_document_from_file" compatibility="9.4.000" expanded="true" height="82" name="Process Documents from Files" width="90" x="179" y="85"> <list key="text_directories"/> <parameter key="file_pattern" value="*.pdf"/> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="UTF-8"/> <parameter key="create_word_vector" value="true"/> <parameter key="vector_creation" value="TF-IDF"/> <parameter key="add_meta_information" value="true"/> <parameter key="keep_text" value="false"/> <parameter key="prune_method" value="none"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <process expanded="true"> <operator activated="true" class="text:transform_cases" compatibility="9.4.000" expanded="true" height="68" name="Transform Cases" width="90" x="45" y="34"> <parameter key="transform_to" value="lower case"/> </operator> <operator activated="true" class="text:tokenize" compatibility="9.4.000" expanded="true" height="68" name="Tokenize" width="90" x="179" y="34"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <operator activated="true" class="text:filter_by_length" compatibility="9.4.000" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="313" y="34"> <parameter key="min_chars" value="4"/> <parameter key="max_chars" value="25"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="9.4.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="447" y="34"/> <connect from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:wordlist_to_data" compatibility="9.4.000" expanded="true" height="82" name="WordList to Data" width="90" x="380" y="85"/> <operator activated="true" class="blending:sort" compatibility="9.10.010" expanded="true" height="82" name="Sort" width="90" x="514" y="85"> <list key="sort_by"> <parameter key="in class (PDF_Files)" value="descending"/> </list> </operator> <operator activated="true" class="filter_example_range" compatibility="9.10.010" expanded="true" height="82" name="Filter Example Range" width="90" x="648" y="85"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="100"/> <parameter key="invert_filter" value="false"/> </operator> <connect from_op="Process Documents from Files" from_port="word list" to_op="WordList to Data" to_port="word list"/> <connect from_op="WordList to Data" from_port="example set" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
