How to implement the Network Optimization in RapidMiner ?
New Altair Community Member
Updated by Jocelyn
dear folks , I am Prabakaran working on building a POV on Supply network optimization for a Retail Chain for which we need to consider Rapidminer as the data science tool.
Meanwhile, we need to perform many POVs on Network Optimization context using Rapidminer. I tried to find relevant Optimization related Operators in the Rapidminer studio
I was not able to find any promising operators. It would be great if you could help/direct me to find the solution with the help of rapidminer.
I would also want to evaluate whether rapidminer can be used for prescriptive intelligence-related tasks ( Mathematical or Meta Heuristics optimization )
Is is possible to build the mentioned use case in RapidMiner - Like how to implement Linear Programming/Integer Programming / Genetic Algorithm / PSO
1 - 1 of
11
This is admittedly not a core function of RapidMiner.
However, you can open Extensions/Marketplace and search, you will find the "Prescriptive Analytics" extension. That should solve some of your problems.
Balázs
