🎉Community Raffle - Win $25
Join and Win
Column Headers File
User: "greyulv"
New Altair Community Member
Updated by Jocelyn
Have a column header file and multiple data files without header.  Need to have the column headers added as example data set.
Attached column_headers.csv file with column names
Attached data file example with multiple rows without column names
Attached XML process trying to use Append operator (fails with no lookup key between two files)
Trying to achieve the following as an example data set
var01,var02,var03,var04
Home,About,Investors,1971
Home,About,Careers,Jobs
Home,About,Team,CEO
Home,About,Privacy,CCPA
1 - 2 of 21
