Difference between Altair Inspire and Solidthinkin Inspire (versions)
What has been changed between the versions? For example doing similar as in: solidThinking 9.5 Design Process and Demo (Bridge topology optimization)
https://www.youtube.com/watch?v=FgbBRVCNebk
In the 2021 version the analyze or optimize does not work if following the old tutorial. Can someone help with what needs to do differently?
I have tried the different solutions but not succeed. Is there some fundamental change?
Hi @Mika Salmi
sT 9.5 has at least 10years maybe. There were several enhancements fro that time to newer versions, but the essence should be the same.
There are several videos in Youtube showing the worflows for Inspire, like the example below.
https://www.youtube.com/watch?v=WApwJbzC76A
Also the tutorials in Inspire help should be very helpful. Did you take a look at them?
It should be pretty straigthforward.
Are you getting any error message?
0 -
Thanks!
I also followed the tutorial for the newest version:
https://2021.help.altair.com/2021/inspire/en_us/topics/inspire/tutorials/tut_sketching_c.htm
Small difference in some values.
For some reason the analyze will not go through - previously it has worked with those settings
Error message is: Analysis Error, Please contact www.altair.com/customer-support
And for Optimize freeze showing 100%
0 -
I uninstalled the whole software and installed it again - now it is working? Thanks for tips!
