🎉Community Raffle - Win $25
Join and Win
YouTube scraper - Python Ooperator help needed
User: "Robi_Me"
New Altair Community Member
Updated by Jocelyn
I am trying to user a Python scraper to collect URL's from a YouTube channel. The Python process works when executing from terminal, but not when I use it inside of the Execute Python operator. My python is not the strongest so I would appreciate any direction in terms of where I am going wrong.
<?xml version="1.0" encoding="UTF-8"?><process version="9.10.000">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.4.000" expanded="true" name="Process" origin="GENERATED_TUTORIAL">
    <process expanded="true">
      <operator activated="true" class="utility:create_exampleset" compatibility="9.10.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="34">
        <parameter key="generator_type" value="comma separated text"/>
        <parameter key="number_of_examples" value="100"/>
        <parameter key="use_stepsize" value="false"/>
        <list key="function_descriptions"/>
        <parameter key="add_id_attribute" value="false"/>
        <list key="numeric_series_configuration"/>
        <list key="date_series_configuration"/>
        <list key="date_series_configuration (interval)"/>
        <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
        <parameter key="time_zone" value="SYSTEM"/>
        <parameter key="input_csv_text" value="https://www.youtube.com/channel/UCrla0VcTLEhGb03wsosZ6SQ"/>
        <parameter key="column_separator" value=","/>
        <parameter key="parse_all_as_nominal" value="false"/>
        <parameter key="decimal_point_character" value="."/>
        <parameter key="trim_attribute_names" value="true"/>
        <description align="center" color="transparent" colored="false" width="126">This is generate data. In prod I use read from DB to get the data</description>
      <operator activated="true" class="python_scripting:execute_python" compatibility="9.3.001" expanded="true" height="103" name="Execute Python" origin="GENERATED_TUTORIAL" width="90" x="179" y="34">
        <parameter key="script" value="import pandas&#10;&#10;def rm_main(data):&#10;    path = &quot;clarifai.csv&quot;&#10;    # store example data in a file&#10;    data.to_csv(path)&#10;    myfile = open(path,'r')&#10;    # return the file&#10;    return(myfile)&#10;"/>
        <parameter key="notebook_cell_tag_filter" value=""/>
        <parameter key="use_default_python" value="true"/>
        <parameter key="package_manager" value="conda (anaconda)"/>
        <parameter key="use_macros" value="false"/>
        <description align="center" color="transparent" colored="false" width="126">Save example data in a csv file and hand the file over to the next Python operator</description>
      <operator activated="true" class="python_scripting:execute_python" compatibility="9.3.001" expanded="true" height="103" name="Execute Python (2)" origin="GENERATED_TUTORIAL" width="90" x="313" y="34">
        <parameter key="script" value="import pandas as pd&#10;from requests_html import HTMLSession&#10;&#10;def rm_main(myfile):&#10;&#9;print('I received the following data set:')&#10;&#9;data = pd.read_csv(myfile, header=None, names=list(('id', 'url')))&#10;&#9;urls = data['url'].tolist()&#10;&#9;for url in urls:&#10;&#10;&#9;&#9;session = HTMLSession()&#10;&#9;&#9;add = url&#10;&#9;&#9;response = session.get(add)&#10;&#9;&#9;response.html.render(sleep=1, keep_page = True, scrolldown = 2)&#10;&#10;&#9;&#9;for links in response.html.find('a#video-title'):&#10;&#9;&#9;&#9;link = next(iter(links.absolute_links))&#10;&#9;&#9;&#9;print(link)&#10;"/>
        <description align="center" color="transparent" colored="true" width="126">Read data from YouTube and return link output</description>
      <connect from_op="Create ExampleSet" from_port="output" to_op="Execute Python" to_port="input 1"/>
      <connect from_op="Execute Python" from_port="output 1" to_op="Execute Python (2)" to_port="input 1"/>
      <connect from_op="Execute Python (2)" from_port="output 1" to_port="result 1"/>
    </process>
</process>
1 - 1 of 11
