How Can I set 3 Column is equally important
wonrada
for Example my Data I have cat's temperament 3 column like lovely, friendly, naughty how to tell program That 3 column is equally important
BalazsBaranyRM
Hi!
Which problem are you trying to solve?
All attributes (columns) are equally important by default, they don't get assigned any
a priori
importance.
However, when you run a modeling algorithm on your data, you might get an assessment of the actual importance
according to this machine learning algorithm
for every attribute. But that's the
result
of the analysis. You can't manually change the outcome of most models, and it would make their result worse, not better.
However, if you get a simple model like from a linear regression, you
can
manually change the coefficients in the formula to emphasize an attribute. It will likely make the model worse in terms of the original success criterion (accuracy, root mean squared error, ...) but it might be better for your use case if you know what you're doing.
Balázs
