Hi Support,
I'm practicing the tutorial "Calibrate Material Model with EDEM and HyperStudy", but after the simulation is finished, the EDEMpy file doesn't work well, and the error message is as follows:
The following are the setup of environment variable and connector preferences:
If there's any solution to this problem, it would be valuable for me.
Thanks and regards,
Gary
