Error in running process: Unexpected H2O job stop: 82
rmlearner1
New Altair Community Member
I am trying to run a process that has been successful before and am getting the following error. Any tips? I've attached the process and data files.
Process failed.
Process failed.
- Exception: com.rapidminer.operator.OperatorException
- Message: Unexpected H2O job stop: 82
- Stack trace:
- com.rapidminer.h2o.operator.H2OLearner.learn(H2OLearner.java:139)
- com.rapidminer.operator.learner.AbstractLearner.doWork(AbstractLearner.java:164)
- com.rapidminer.operator.Operator.execute(Operator.java:1023)
- com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
- com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:805)
- com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:800)
- java.security.AccessController.doPrivileged(Native Method)
- com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:800)
- com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:423)
- com.rapidminer.Process.executeRoot(Process.java:1464)
- com.rapidminer.Process.lambda$executeRootInPool$5(Process.java:1443)
- com.rapidminer.studio.concurrency.internal.AbstractConcurrencyContext$AdaptedCallable.exec(AbstractConcurrencyContext.java:362)
- java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289)
- java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056)
- java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692)
- java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:175)
- Cause
- Exception: java.lang.ArrayIndexOutOfBoundsException
- Message: 82
- Stack trace:
- hex.glm.GLMTask$GLMGradientTask.computeCategoricalEtas(GLMTask.java:450)
- hex.glm.GLMTask$GLMGradientTask.map(GLMTask.java:549)
- water.MRTask.compute2(MRTask.java:650)
- water.MRTask.compute2(MRTask.java:601)
- water.H2O$H2OCountedCompleter.compute1(H2O.java:1574)
- hex.glm.GLMTask$GLMBinomialGradientTask$Icer.compute1(GLMTask$GLMBinomialGradientTask$Icer.java)
- water.H2O$H2OCountedCompleter.compute(H2O.java:1570)
- jsr166y.CountedCompleter.exec(CountedCompleter.java:468)
- jsr166y.ForkJoinTask.doExec(ForkJoinTask.java:263)
- jsr166y.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:974)
- jsr166y.ForkJoinPool.runWorker(ForkJoinPool.java:1477)
- jsr166y.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:104)
