How to compare classification models in the same time with compare their ROCs, this is my process?
Aprile
New Altair Community Member
I'm obstetrician and on my research project about how to early diagnosis ectopic pregnancy before severe complication occur using Rapidminer.
Right now I have watched and learned from many of your vdo and consult my consultant who had use Rapidminer before --> Right now I had achieved the analysis result, which I hope it could work on real life in hospital.
But I do realized that I'm not the expert here, so may I consult about the process/ workflow that I used the command in your programme for the most valid part.
Would you mind if I send you the process flow to check If I'm wrong? I'm truly thankful.
