How to change the resolution
michel7
all elements (except the OS windows title - see green arrow) are nearly pixaleted:
How to adjust it ?
Thanks a lot,.
Michel
michel7
An other application, DBVisualizer uses java as well, but it has nor issues with fonts and pixel:
Here some settings of DBVisualizer:
Product: DbVisualizer Pro 13.0 [EVALUATION] (build: 3261)
OS: Windows 11
OS Version: 10.0
OS Arch: amd64
Java Version: 11.0.14
Java VM: OpenJDK 64-Bit Server VM
Java Vendor: Eclipse Adoptium
Java Home: c:\sw\dbvisualizer\jre
awt.toolkit sun.awt.windows.WToolkit
exe4j.consoleCodepage cp0
exe4j.isInstall4j true
exe4j.launchName C:\sw\DbVisualizer\dbvis.exe
exe4j.moduleName C:\sw\DbVisualizer\dbvis.exe
exe4j.semaphoreName Local\c:_sw_dbvisualizer_dbvis.exe
exe4j.tempDir
exe4j.unextractedPosition 0
file.encoding Cp1252
file.separator \
flatlaf.menuBarEmbedded true
install4j.appDir C:\sw\DbVisualizer\
install4j.exeDir C:\sw\DbVisualizer\
install4j.launcherId 2
install4j.swt false
java.awt.graphicsenv sun.awt.Win32GraphicsEnvironment
java.awt.printerjob sun.awt.windows.WPrinterJob
java.class.version 55.0
java.net.useSystemProxies false
java.runtime.name OpenJDK Runtime Environment
java.runtime.version 11.0.14+9
java.specification.name Java Platform API Specification
java.specification.vendor Oracle Corporation
java.specification.version 11
java.util.Arrays.useLegacyMergeSort true
java.vendor Eclipse Adoptium
java.vendor.url
https://adoptium.net/
java.vendor.url.bug
https://github.com/adoptium/adoptium-support/issues
java.vendor.version Temurin-11.0.14+9
java.version 11.0.14
java.version.date 2022-01-18
java.vm.compressedOopsMode 32-bit
java.vm.info mixed mode
java.vm.name OpenJDK 64-Bit Server VM
java.vm.specification.name Java Virtual Machine Specification
java.vm.specification.vendor Oracle Corporation
java.vm.specification.version 11
java.vm.vendor Eclipse Adoptium
java.vm.version 11.0.14+9
jdk.debug release
line.separator
logger.level.override sun.util.logging.PlatformLogger=SEVERE
os.arch amd64
os.name Windows 11
os.version 10.0
path.separator ;
sun.arch.data.model 64
sun.awt.enableExtraMouseButtons true
sun.awt.noerasebackground true
sun.boot.library.path c:\sw\dbvisualizer\jre\bin
sun.cpu.endian little
sun.cpu.isalist amd64
sun.desktop windows
sun.io.unicode.encoding UnicodeLittle
sun.java.command C:\sw\DbVisualizer\dbvis.exe
sun.jnu.encoding Cp1252
sun.locale.formatasdefault true
sun.management.compiler HotSpot 64-Bit Tiered Compilers
sun.os.patch.level
user.country US
user.dir C:\sw\DbVisualizer
user.home C:\Users\laszl
user.language en
user.name laszl
user.script
user.timezone Europe/Berlin
user.variant
DbVisualizer uses software from the diagramming company yWorks, the
creator of the extensive yFiles diagramming libraries for Java, .NET,
and JavaScript. yFiles enables you to add high-quality diagramming
functionality to your own software applications.
Any ideas ?
Thanks a lot in advance,
Michel
michel7
Am I the only one wit that issue ?
michel7
Problem solved, but I don't know how
