How can I Create a Patch Manually for Separate Volumes? Ref: NVH-1000 tutorial
User: "John Anderson"
Altair Community Member
Updated by John Anderson
The NVH-1000 tutorial, step 9, asks me to create a patch manually for separate volumes but gives no instructions on how to do this. I've tried a few things without success. Could someone walk me through this? For Altair: I think this tutorial needs updating.
1 - 2 of 21
    User: "Xiaolei"
    Updated by Xiaolei
    Hi John,
    One way to create a patch manually is using whatever panels to create some elements, such as Hole/Gap Fill, F6(2D-edit element), or 2D-ruled. It doesn't matter if the element size is big, or the element quality is bad, because patching the holes is the purpose.
    It's a method we used often to patch panels, then we can get a better cavity volume.
    Thanks.
    Xiaolei
    User: "Xiaolei"
    Updated by Xiaolei
    Please also make sure, in step 9, when you use Mesh > Hole/Gap Fill. You should access Mesh from drop down menu, not the Mesh button inside of AcousticCavity session.
    The drop down menu of Mesh > Hole/Gap Fill is a separate panel, so in NVH-1000, we didn't elaborate in detail. If you search key words: Fill Holes, Gaps, Patches you can find the corresponding help document.
