Altair RISE
Nominate Yourself Now!
New Added Operators Lacking MetaData
User: "btibert"
New Altair Community Member
Updated by Jocelyn
I don't remember this "issue" coming up as frequently as it has in the past, but this semester, I have noticed that in RM 9.10, the newly connected operators are unware to the metadata from earlier in the process.  I do have Sync MetaData checked, but I am unaware of any other "fix" or flow that I should be following.  To demonstrate what I believe is a common flow, I recorded a video highlighting my situation/issue.
https://youtu.be/MMYZDRtywoI
1 - 1 of 11
    User: "MartinLiebig"
    Accepted Answer
    if you don't run the wizard you need to define the meta data manually. There is a list for it in the Read CSV operator. The wizard is doing this for you, which is of course way nicer.
    Best,
    Martin
