Hello to all friends
I intend to use FP-growth With k-means clustering and compare the result with when I use only PF-growth. I have done this implementation but the results of both implementations are the same while they should be different. Can anyone tell me where I's wrong and what I need to change? I have used the Movielens 100k dataset. I have attached my files to you so that you can better guide me.
Thank you in advance for your help
