Hello All,
I am looking for a behavioral voltage source option in PSIM? The voltage source should take another source property (ampltiude, frequency, phase) as its input.
Thanks
Ashik
Please click "Elements >> Sources >> Voltage", you will see many ways to implement your voltage source.
The "Voltage controlled " voltage source accepts control signals.
If you have a math model which can extract the amplitude, frequency and phase from a signal, you may use PSIM's control function blocks to implement your algorithm. Then, feed the signal to the input of the voltage-controlled voltage source.
