Dec 20, 2021 3:20:45 PM com.rapidminer.gui.tools.ProgressThread$3 run WARNING: Error executing background job Checking repository location (Retrieve): java.lang.IllegalStateException: filter can not be replaced with null filter java.lang.IllegalStateException: filter can not be replaced with null filter at java.io.ObjectInputStream.setInternalObjectInputFilter(ObjectInputStream.java:1316) at java.io.ObjectInputStream.access$000(ObjectInputStream.java:218) at java.io.ObjectInputStream$1.setObjectInputFilter(ObjectInputStream.java:290) at sun.misc.ObjectInputFilter$Config.setObjectInputFilter(ObjectInputFilter.java:392) at com.rapidminer.repository.resource.ResourceIOObjectEntry.lambda$readMetaDataObject$0(ResourceIOObjectEntry.java:166) at java.security.AccessController.doPrivileged(Native Method) at com.rapidminer.repository.resource.ResourceIOObjectEntry.readMetaDataObject(ResourceIOObjectEntry.java:165) at com.rapidminer.repository.resource.ResourceIOObjectEntry.retrieveMetaData(ResourceIOObjectEntry.java:97) at com.rapidminer.operator.io.RepositorySource$1.run(RepositorySource.java:133) at com.rapidminer.gui.tools.ProgressThread$3.run(ProgressThread.java:586) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748)
