About Multiple Regression Model
Tansu
Hey there
I am about to get crazy.
I am trying to set up multiple linear regression, but at the end of the operations, the variables and their coefficients do not appear in the result section. It's just the slope result. So, I can't set up the regression equation.
I am following the path as retrieve fiile-set role (fix the variables)-cross validation-linear regression-apply model-performance regression
Please help.
Jerwuney
Hi Tansu
When you run your model, you should see "LinearRegression" tab among those tabs you will get at the results window. Click on it, and to its left, you should see three icons, 'Data', 'Description' and 'Annotations'. The variables with their coefficients are at the 'Description' icon.
Note that RapidMiner will only give you those that are important. Check that with your p-values and the code it attaches to each variable.
Best regards.
Tansu
Dear Jerwuney
Thank you for your comment. I really appreciate it.
However, I am having the same problem. I have followed the path you described but I only got root mean squared error, relative error, correlation which are already expected.
I have 6 variables affecting my dependent variable in my data set. When I chose particular one of them in set operator, I dont get any coefficient neither in the linear regression tab nor in description icon. Strangely enough, I get coefficients if I chose one of the remaining five. Thats the problem I cannot sort out. May I send you my data list through mail if possible?
Jerwuney
Hi
@Tansu
Feel free to attach your data and model here. There are many others who are willing to add more aid.
You might be looking at the 'Performance' tab instead, thus, seeing only those correlation and others. Or maybe, you didn't connect the "model" node of your 'apply model' parameter to the output.
Please check well.
Jerwuney
Tansu
Thank you dear Jerwuney
The data set is below.
My dependent value is the energy produced in the turbine.
Other 5 are independent variables.
As I said, when I take the energy produced in the turbine as dependent variable, no coefficient appears. However, when I take one of the remaining five, no problem occurs.
Also, I discovered something called generalized linear regression. I get coefficient by using that one. Is it the same as linear regression? Because, the prediction values seem pretty close to actual ones.
And one more thing:) Please show me the way to write the file in excel by using write excel operator. I couldnt figure out how to connect and what to connect.
I know, I am being a bit too much, but very curious. Sorry about that.
Air temperature cooler inlet
Cooler inlet relative humidity (%)
Air saturation pressure (mbar)
Air temperature cooler outlet
Aooler outlet relative humidity (%)
The energy produced in the turbine
24,5
73,3
971
24,2
88,53
217
24,8
72,7
969
23,58
93,52
217
25,3
67,6
967
23,73
93,6
215
25,5
70,1
977
23,9
93,2
216
26
67,1
973
23,4
93,15
218
26,3
65,5
982
23,66
92,3
216
26,4
59,1
979
24,11
92,79
216
26,5
70,9
981
23,44
92,76
219
27,1
64,6
962
23,94
93,35
215
27,5
62,8
983
24,06
92,51
215
28,8
58,1
959
23,85
93,08
215
29,5
57,2
983
24,08
92,4
215
29,7
56,7
957
23,98
92,67
214
30,7
51,9
955
24,21
92,59
215
31,2
48,4
961
23,87
92,74
220
34
39,5
949
24,23
91,74
211
34
39,5
949
24,23
91,74
211
35,2
39,6
962
23,9
91,37
215
36,1
37,3
957
24,3
90,17
214
36,7
37,9
960
24,42
90,18
212
36,8
32,9
947
24,27
90,98
213
36,8
32,9
947
24,27
90,98
213
37
33,9
953
24,31
90,52
213
37,1
31,3
949
24,39
89,08
212
37,1
31,3
947
24,39
89,08
212
37,3
29,2
953
24,43
88,68
212
37,3
29,2
949
24,43
88,68
212
37,5
33,2
954
24,45
90,88
211
34
29,2
953
24,43
88,68
212
33,8
31,3
949
224,39
89,08
212
31,1
32,9
947
24,27
90,98
213
31,2
39,6
947
24,23
91,74
211
30,7
51,9
969
24,21
92,59
215
29,7
56,7
955
23,98
92,67
214
28,8
58,1
957
23,85
93,08
215
27,1
64,6
959
23,94
93,35
216
25,3
57,6
962
23,73
93,6
216
24,8
72,7
967
23,58
93,52
217
24,5
73,8
969
24,2
88,53
218
26
67,1
971
23,4
93,15
218
26,6
70,1
973
23,9
93,2
216
26,4
69,1
977
24,11
92,79
216
24,5
70,9
979
21,44
92,76
219
26,3
65,5
981
23,66
92,3
216
27,5
62,8
982
24,06
92,51
210
29,5
57,2
983
24,08
92,4
213
31,2
48,4
983
23,87
92,74
212
35,2
39,6
961
23,9
91,37
215
36,7
37,9
962
24,42
90,18
212
36,1
37,3
960
24,3
90,17
214
37,5
33,2
957
24,45
90,88
211
37
34,2
979
24,31
90,52
213
37,3
36,5
981
24,43
88,68
212
37,1
35,4
982
24,39
89,08
212
36,8
33,2
983
24,27
90,98
213
34
37,8
983
24,23
91,74
211
37.6
33.2
961
24.45
90.88
211
37
35
965
23,2
90.5
218
36.8
32.9
972
24,7
90.98
213
36.1
37.3
973
24,3
91.7
214
35.5
26,7
975
23.68
92,4
223
34
36,6
977
24,23
91,74
211
33.6
39,8
958
24,23
91,18
210
33
40
965
22,1
90
214
32.9
47.6
966
24.19
92.4
211
32.5
45
967
27
90
212
32
50
964
25,7
90
214
31.2
66.4
963
23.87
92.74
220
31
66.5
982
24
90
215
30
41
983
23,4
90
217
29,6
49
983
26
90
218
29,3
57.4
961
23.83
93.35
215
28,8
58.1
965
23.84
93.08
215
28,8
60,4
972
25
90
214
28,5
51
973
25
90
214
28,1
63,2
975
23,96
93,8
214
27,5
62,8
977
24,06
92,51
215
26,7
68,8
958
23,27
93,36
214
25
75
965
22
90
218
24,3
51,9
963
23,74
92,59
215
20,7
72
961
19
90
225
36,6
37,9
985
29,8
90
209
36,6
37,8
985
30,6
90
204
36,8
34,2
975
31
90
208
37
33,2
954
23,97
90,38
216
38,2
29,7
953
23,77
88,41
216
37,3
30,9
949
23,83
89,06
217
36,8
32,9
947
23,73
91,21
216
34
39,6
947
23,86
91,58
218
30,7
51,9
949
23,73
92,49
216
29,8
56,5
955
23,17
92,99
216
27,8
57,1
957
22,97
93,46
222
26,8
62,2
959
23,33
93,74
219
25,3
67,6
962
23,03
93,53
222
24,9
70,3
957
22,75
93,85
221
24,5
74,5
969
22,83
94,02
222
26
67,1
971
22,36
93,28
220
26,6
70,1
973
23,16
93,58
220
26,4
69,1
977
22,96
93,02
220
26,4
31,2
979
22,18
93,28
220
24,5
65,2
979
22,24
93,58
220
25,9
63,2
981
23,08
93,92
222
28,1
57,4
982
23,11
93,88
222
29,3
48,6
983
23,08
93,23
221
31
41,4
983
23,46
93,05
221
32,9
40
984
23,744
93,17
220
32,9
40
984
23,43
92,78
222
32,9
40
985
23,63
84
221
33,8
38,6
985
23,63
92,17
220
32,1
47,6
986
23,15
93,18
220
25,3
67,6
954
23,68
93,73
215
24,9
70,3
947
23,61
93,59
215
24,5
74,4
954
23,74
93,63
214
26,1
66
947
23,74
93,36
214
26,4
69,9
959
23,88
93,78
215
26,7
68,8
949
23,91
93,88
214
24,6
71
959
23,88
93,78
215
26
65,4
967
23,28
93,58
215
28,1
63,2
977
23,96
93,8
214
29,3
57,4
953
23,83
93,35
215
31
48,6
949
24
93,03
215
33,3
42,4
962
23,76
91,18
213
31
40,6
923
23,87
91,92
212
33,3
42,4
962
23,76
91,18
213
31
40,6
923
23,87
91,92
212
33,36
38,8
954
24,23
91,18
210
32,9
47,6
947
24,18
92,4
211
32,9
47,1
959
24,33
92,7
211
33,1
44,5
971
24,1
91,2
211
32,7
43,89
981
2,9
91,18
213
31,3
42,1
947
23,87
91,79
213
30,6
50,8
954
23,86
92,44
213
28,9
55,6
947
23,79
92,8
214
27,1
62,1
954
23,62
93,23
216
26,3
64,4
947
25,73
91,8
916
26,2
63,4
959
26,1
93
215
Jerwuney
Hi
@Tansu
Please check here [
https://community.rapidminer.com/discussion/51369]
on how to attach data and a model. It will make it easy for people to access.
For writing an excel file, you can find video tutorials on that [
https://academy.rapidminer.com/courses/data-loading-via-a-process]
or even on YouTube.
Jerwuney
