I am trying to execute Tesseract to extract detail from PDF's that have been converted to PNG. Any idea why I am getting an error 127 when I am able to execute via terminal?
<?xml version="1.0" encoding="UTF-8"?><process version="9.10.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.10.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="concurrency:loop_files" compatibility="9.10.000" expanded="true" height="103" name="Loop Files" width="90" x="179" y="85">
<parameter key="directory" value="/Users/robinmeisel/Dropbox/master_png/Autoseis"/>
<parameter key="filter_type" value="glob"/>
<parameter key="recursive" value="false"/>
<parameter key="enable_macros" value="true"/>
<parameter key="macro_for_file_name" value="file_name"/>
<parameter key="macro_for_file_type" value="file_type"/>
<parameter key="macro_for_folder_name" value="folder_name"/>
<parameter key="reuse_results" value="false"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="text:create_document" compatibility="9.3.001" expanded="true" height="68" name="Create Document" width="90" x="112" y="136">
<parameter key="text" value="tesseract %{file_name} %{file_name}.txt"/>
<parameter key="add label" value="false"/>
<parameter key="label_type" value="nominal"/>
<operator activated="true" class="text:write_document" compatibility="9.3.001" expanded="true" height="82" name="Write Document" width="90" x="246" y="136">
<parameter key="file" value="/Users/robinmeisel/Dropbox/master_png/Autoseis/tesseract.sh"/>
<parameter key="overwrite" value="true"/>
<operator activated="true" class="productivity:execute_program" compatibility="9.10.000" expanded="true" height="124" name="Execute Program (2)" width="90" x="380" y="136">
<parameter key="command" value="chmod +x tesseract.sh"/>
<parameter key="log_stdout" value="true"/>
<parameter key="log_stderr" value="true"/>
<parameter key="working_directory" value="/Users/robinmeisel/Dropbox/master_png/Autoseis"/>
<list key="env_variables"/>
<operator activated="true" class="productivity:execute_program" compatibility="9.10.000" expanded="true" height="103" name="Execute Program" width="90" x="514" y="136">
<parameter key="command" value="./tesseract.sh"/>
<connect from_op="Create Document" from_port="output" to_op="Write Document" to_port="document"/>
<connect from_op="Write Document" from_port="document" to_op="Execute Program (2)" to_port="through 1"/>
<connect from_op="Execute Program (2)" from_port="out" to_op="Execute Program" to_port="in"/>
<connect from_op="Execute Program" from_port="out" to_port="output 1"/>
<connect from_op="Execute Program" from_port="err" to_port="output 2"/>
<portSpacing port="source_file object" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
<portSpacing port="sink_output 3" spacing="0"/>
</process>
<connect from_op="Loop Files" from_port="output 1" to_port="result 1"/>
<connect from_op="Loop Files" from_port="output 2" to_port="result 2"/>
</process>
</process>
