When I open Inspire Cast 2019.3.1, I have this mistake:
I am using Windows 10 and I have Folder Redirection of My Documents to a network folder. I think that´s the problem
Any idea?
Hi Maria,
Is the network path available when you start Inspire Cast?
If yes, can you please try and remove the file print_materials.xml there and see if it solved the problem?
Thanks,
Matthieu
