<?xml version="1.0" encoding="UTF-8"?><process version="9.10.001"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.10.001" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="generate_data" compatibility="9.10.001" expanded="true" height="68" name="Generate Data" width="90" x="179" y="34"><br> <parameter key="target_function" value="random"/><br> <parameter key="number_examples" value="100"/><br> <parameter key="number_of_attributes" value="5"/><br> <parameter key="attributes_lower_bound" value="-10.0"/><br> <parameter key="attributes_upper_bound" value="10.0"/><br> <parameter key="gaussian_standard_deviation" value="10.0"/><br> <parameter key="largest_radius" value="10.0"/><br> <parameter key="use_local_random_seed" value="false"/><br> <parameter key="local_random_seed" value="1992"/><br> <parameter key="datamanagement" value="double_array"/><br> <parameter key="data_management" value="auto"/><br> </operator><br> <operator activated="true" class="utility:create_exampleset" compatibility="9.10.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="179" y="187"><br> <parameter key="generator_type" value="comma separated text"/><br> <parameter key="number_of_examples" value="100"/><br> <parameter key="use_stepsize" value="false"/><br> <list key="function_descriptions"/><br> <parameter key="add_id_attribute" value="false"/><br> <list key="numeric_series_configuration"/><br> <list key="date_series_configuration"/><br> <list key="date_series_configuration (interval)"/><br> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/><br> <parameter key="time_zone" value="SYSTEM"/><br> <parameter key="input_csv_text" value="First Att, Second Att att1, att2 att3, att4"/><br> <parameter key="column_separator" value=","/><br> <parameter key="parse_all_as_nominal" value="false"/><br> <parameter key="decimal_point_character" value="."/><br> <parameter key="trim_attribute_names" value="true"/><br> </operator><br> <operator activated="true" class="extract_macro" compatibility="9.10.001" expanded="true" height="68" name="Extract Macro" width="90" x="313" y="187"><br> <parameter key="macro" value="nExa"/><br> <parameter key="macro_type" value="number_of_examples"/><br> <parameter key="statistics" value="average"/><br> <parameter key="attribute_name" value=""/><br> <list key="additional_macros"/><br> </operator><br> <operator activated="true" class="concurrency:loop" compatibility="9.10.001" expanded="true" height="103" name="Loop" width="90" x="447" y="34"><br> <parameter key="number_of_iterations" value="%{nExa}"/><br> <parameter key="iteration_macro" value="iteration"/><br> <parameter key="reuse_results" value="true"/><br> <parameter key="enable_parallel_execution" value="false"/><br> <process expanded="true"><br> <operator activated="true" class="extract_macro" compatibility="9.10.001" expanded="true" height="68" name="Extract Macro (2)" width="90" x="112" y="85"><br> <parameter key="macro" value="firstAtt"/><br> <parameter key="macro_type" value="data_value"/><br> <parameter key="statistics" value="average"/><br> <parameter key="attribute_name" value="First Att"/><br> <parameter key="example_index" value="%{iteration}"/><br> <list key="additional_macros"><br> <parameter key="secondAtt" value="Second Att"/><br> </list><br> </operator><br> <operator activated="true" class="delay" compatibility="9.10.001" expanded="true" height="103" name="Delay" width="90" x="246" y="34"><br> <parameter key="delay" value="fixed"/><br> <parameter key="delay_amount" value="0"/><br> <parameter key="min_delay_amount" value="0"/><br> <parameter key="max_delay_amount" value="1000"/><br> <description align="center" color="transparent" colored="false" width="126">just to ensure exec order</description><br> </operator><br> <operator activated="true" class="generate_attributes" compatibility="9.10.001" expanded="true" height="82" name="Generate Attributes" width="90" x="380" y="34"><br> <list key="function_descriptions"><br> <parameter key="delta_%{firstAtt}_%{secondAtt}" value="eval(%{firstAtt})-eval(%{secondAtt})"/><br> </list><br> <parameter key="keep_all" value="true"/><br> </operator><br> <connect from_port="input 1" to_op="Delay" to_port="through 1"/><br> <connect from_port="input 2" to_op="Extract Macro (2)" to_port="example set"/><br> <connect from_op="Extract Macro (2)" from_port="example set" to_op="Delay" to_port="through 2"/><br> <connect from_op="Delay" from_port="through 1" to_op="Generate Attributes" to_port="example set input"/><br> <connect from_op="Delay" from_port="through 2" to_port="output 2"/><br> <connect from_op="Generate Attributes" from_port="example set output" to_port="output 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="source_input 2" spacing="0"/><br> <portSpacing port="source_input 3" spacing="0"/><br> <portSpacing port="sink_output 1" spacing="0"/><br> <portSpacing port="sink_output 2" spacing="0"/><br> <portSpacing port="sink_output 3" spacing="0"/><br> <description align="center" color="yellow" colored="false" height="67" resized="false" width="126" x="412" y="134">now we can work with firstAtt and secondAtt</description><br> </process><br> </operator><br> <connect from_op="Generate Data" from_port="output" to_op="Loop" to_port="input 1"/><br> <connect from_op="Create ExampleSet" from_port="output" to_op="Extract Macro" to_port="example set"/><br> <connect from_op="Extract Macro" from_port="example set" to_op="Loop" to_port="input 2"/><br> <connect from_op="Loop" from_port="output 1" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
When I pasted the XML and checked the green mark it turned out nothing there. What was wrong? Thanks!
The log shows: PM WARNING: Invalid process xml!
