import pandas as pd import numpy as np # rm_main is a mandatory function, # the number of arguments has to be the number of input ports (can be none), # or the number of input ports plus one if "use macros" parameter is set # if you want to use macros, use this instead and check "use macros" parameter: #def rm_main(data,macros): def rm_main(): df = pd.DataFrame({'x':np.arange(1,10)}) return df
