Subprocess Caching - Nullpointer Exception
I built a simple process with a suprocess(caching) in the beginning where simply I pull data from a database.
When I start executing the process I get an error: Process failed with the following message:
Exception: java.lang.NullPointerException
Can you fix this bug in the operator toolbox extension or help if you know how I can fix this in my process or setup?
- Message: null
- Stack trace:
- com.rapidminer.extension.operator_toolbox.operator.utility.CachingSubprocess.hashEmbeddedProcess(CachingSubprocess.java:315)
- com.rapidminer.extension.operator_toolbox.operator.utility.CachingSubprocess.doWork(CachingSubprocess.java:217)
- com.rapidminer.operator.Operator.execute(Operator.java:1023)
- com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
- com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:805)
- com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:800)
- java.security.AccessController.doPrivileged(Native Method)
- com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:800)
- com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:423)
- com.rapidminer.Process.executeRoot(Process.java:1464)
- com.rapidminer.Process.lambda$executeRootInPool$5(Process.java:1443)
- com.rapidminer.studio.concurrency.internal.AbstractConcurrencyContext$AdaptedCallable.exec(AbstractConcurrencyContext.java:362)
- java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289)
- java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056)
- java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692)
- java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:175)
1 - 1 of
11
MichaelKnopf
New Altair Community Member
Accepted Answer
Hi there,
thanks for reporting this. It is caused by embedded operators with undefined parameters that do not have a default value. Unfortunately, one cannot always tell whether a parameter has a default value or not from the UI.
However, the bug fix is straight forward and should make it into the next extension update.
Thanks,
Michael
1 - 1 of
11
Hi there,
Thanks,
Michael
